05-26-2019, 02:43 PM | #1 |
Drives: 2010 ss Join Date: Jun 2014
Electric steering conversion Has anybody done it?
I did a search didn’t come up with anything. Has anybody swap the Electric steering out of a 14-15 into a 2010-2011? I was wondering if this can be done?
Thanks
2010ss L99 to a ls3 s480 turbo lil john cam tuned by james short
05-26-2019, 03:59 PM | #2 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I'm sure it can. Lots of swapping parts, pump, steering rack, sensors, computer updates...and what not. In most cases, if the electric steering goes bad, you cannot steer at all. Why do you want to swap?
More to come. |
05-26-2019, 04:28 PM | #3 |
Clean up the engine bay and make more room. The plug on the motor just two o rings it looks like power and ground. Not like a plug with multiple wires. I was thinking the computer didn’t see it maybe. Just a idea
05-26-2019, 04:38 PM | #4 | |
SomeguyK
Edit: I'm sure if you found a donor vehicle it would make the swap easier.
More to come. |
05-26-2019, 04:49 PM | #5 |
376 cubic inches of fun
I'm thinking the control system issues are not worth trying to overcome. Sounds like a can of worms.
Besides, hydraulic power steering gives you more feedback through the steering wheel. |
05-26-2019, 04:56 PM | #6 |
Your right probably a head ache. Motor comes on the rack I did see a plug off the motor that when to the car harness
05-26-2019, 11:17 PM | #7 |
I wondered about electronic steering from the first time I heard it existed. If it's true that the electric steering can go bad and cause complete loss of steering how can this even be considered for vehicles? Scary to me. I just seems like some systems should be designed to work to some degree (steering, brakes) even with engine off. Can you steer electronic steering with the engine off and if not how do you move the vehicle around when it's broke down?
05-26-2019, 11:29 PM | #8 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
With the electric steering, it's just electric assisted. If the power to the rack fails for any reason, you can still steer, it's just like normal power steering if the pump fails.
Steering still functions, it just takes more effort. |
05-27-2019, 11:26 AM | #9 |
Good to know. Thanks.
05-27-2019, 02:40 PM | #10 | |
I think the only real benefit would be to maybe get that 5hp back that the hydraulic system robs (and space, like you said), other than that I would prefer the feel and reliability of the older style steering.
05-27-2019, 10:14 PM | #11 |
Drives: 2012 SS Join Date: Feb 2016
I would stick with the hydraulic steering myself. Getting rid of the p/s pump will not clean up the engine compartment much as the elec. steering cars have an idler pulley in its place. Next thing is when things go wrong I am sure that the elec. steering is more costly to repair. Just my opinion.
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
