05-29-2019, 08:48 PM | #1 |
Drives: 2010 SS L99 Join Date: Sep 2018
Chris49066SS Build Thread GPI
Mod List Induction & Exhaust JRE Race Scoop Z-28 cold air intake Nick Williams 102mm throttle body LOD X-1 Intake Manifold w/ 102mm snout FIC 850cc Injectors GPI ported heads w/ LS3 hollow stem intake valves TSP 2" long tube headers w/ JetHot ceramic coat Jegs turn-downs Dyno tuned by Ben @ GPI 525rwhp@7600rpm 407 ft/lbs@6100rpm Valvetrain 11:1 compression ratio 93 octane Powerbond Damper GPI SS4 cam (Flycut) CHE trunnion upgrade kit PAC .700 valve springs GPI 5/16" hardened pushrods GM racing lifters LS2 Dogbone style dampener Cometic head gaskets Mighty Mouse Wild catch can Drivetrain ADM transmission cooler Circle D 5C torque converter GM 1LE 3.91 gears Suspension Front Sway bar removed Pegasus solid cradle bushings BMR solid motor mounts Prothane polyurethane transmission mount BMR trailing arms, poly outer bushings, non-adjustable BMR toe rods, non-adjustable SPC camber bolts Wheels & Tires Race Star 17x10.5 rear wheels & Mickey Thompson ET Street S/S Race Star 17x4.5 front wheels & M&H bias ply 28x4.5s Hurst Line Lock Weight Reduction Removed passenger seat and rear seat Exhaust (headers w/ dumps) Front crash bar Front sway bar Washer bottle and lines Trunk/everything except battery & wall lining Floor mats Some interior panels 3,740 lb race weight 3,530 lb without driver Cosmetics Heritage Grill ------------------------------------------------------------------ Bests as of 16 November 2019 60' - 1.564 1/8 - 7.084 1/4 - 11.079 Well, I felt like its a little overdue but I wanted to start a build thread. Its going to take a minute to catch it up, but I have most of the pictures I took from many of the mods, even if there aren't really all that many mods. I bought the car in March of 2015, a completely stock 2010 Camaro SS/RS, with 24,000 miles. Its a west coast car, so it has seen almost no road salt. It was at first a mild mannered daily driver with the headers and cold air intake that I installed, but that just wasn't enough for me, so in 2018, I started slowly transforming it into a weekend cruiser with no road courses in mind, but a high RPM drag racing car. Thanks for viewing, and plenty more pics are on the way! Here is the first one the day after I drove it off the lot, before I had a license plate. Yes, the state of Washington requires a front mounted license plate, AND someone drilled the bumper to install it before I got it This was that summer.. it was sporting a cold air intake and a muffler delete.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 Last edited by Chris49066SS; 10-19-2022 at 02:39 PM. |
05-30-2019, 02:34 AM | #2 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
Badass. That’s a big cam. Did they try and sell you cylinder heads?
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
05-30-2019, 06:13 AM | #3 |
Thank you! Actually, no, they asked if I wanted to have them rod mod my intake manifold, but my budget had already maxed out. They put on some head gaskets from Cometic and were able to bump the compression up to 11.1 without milling. Heads would've been awesome but it just wasn't feasible that time. It still isn't, after this little batch of upcoming mods (new headers, LOD intake manifold and CHE trunnion upgrade). I will likely wait to do the heads until I do my fuel system.
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
05-30-2019, 06:41 AM | #4 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
Very nice ET!
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
05-30-2019, 08:42 AM | #5 |
Thanks John. I am aiming for a similar build as yours. Looks pretty solid, man!
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 Last edited by Chris49066SS; 06-02-2019 at 10:28 AM. |
05-30-2019, 05:01 PM | #6 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
thats what i said moments after i bought the car. ain't it funny
Bone Stock |
05-30-2019, 05:10 PM | #7 |
Heh for sure
05-30-2019, 07:25 PM | #8 |
Drives: White 2013 SS/RS l99 Join Date: May 2016
I’m glad you posted this. I do major lurking on here and every time I see your sig in a thread with that burnout pic , awesome car man!!! I see you are in tn, who did your cam install and tune? Every shop around Atlanta I talk to always wants to get rid of vvt. Gpi is 12 hrs from me, would be nice to find a shop closer to home that can handle a vvt cam
Current: 2013 summit white Camaro 2SS l99 CAI, long tubes, ported tb, tune Previous: 2008 jet stream blue Corvette Z06 Airraid, Corsa, MGW shifter SOLD |
05-30-2019, 07:28 PM | #9 |
Dont get rid of the VVT if you drive it on the street. Its a plus because of valve timing flexibility
If you're going full send, then get rid of it Sent from my SM-G975U using Tapatalk
Bone Stock |
05-30-2019, 07:29 PM | #10 |
Drives: 2010 Camaro 2SS/RS M6 Join Date: May 2009
Cool, Chris. Glad to see you starting a journal/build thread. Your car hauls ass dude!!! That 60' blows my mind, but your ET is very impressive as well. Looking forward to updates.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings Hotchkis sub-frame brace Stop Tech Z-23 brakes 4.10 gears, Eaton Truetrac, LPW diff cover Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA |
05-30-2019, 07:35 PM | #11 |
yes. that 60'
Bone Stock |
05-30-2019, 08:58 PM | #12 | |
GPI did my cam, and Ryan Stevens did my tune. He did a street and dyno tune. Top notch shop! Thanks Z, thanks Fordkiller! I'm gonna post some more updates as soon as they come.
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 Last edited by Chris49066SS; 06-20-2019 at 05:59 PM. |
05-30-2019, 09:30 PM | #13 | ||
Chapter 1 2015-2017
This was the first mod to my car, very expectedly, as I was not familiar with the plethora of aftermarket goodies and support for the 5th Gen Camaros. The tried and true from the 90s, watching Horsepower TV and wandering AutoZone looking for air filters and wondering how much horsepower some Royal Purple Oil would free up...Get a K&N!
A few months went by, and I went ahead and got these 1 7/8 long tube headers from Texas Speed & Performance. They looked awesome next to the stock boat anchors, and were so much lighter! I chose the catless option, and a buddy and I got them installed in a little less than 2 hours. Such an easy mod, and when we fired it up (I already had done the muffler and resonator delete, mind you) I grinned from ear to ear. Now I was loud, right? Shiny new headers, ironic picture though, later in the journal when I catch it up to current, you will see why.. We took it out to the back 40 for a little sound test, and here it was, a straight piped stock L99 with only long tube headers and a cold air intake...eeghh Now given that, just imagine the AFM kicking in. until I found the way to get around it. But really, all I needed was a tune. Maybe a performance chip would do the trick, right? Fast forward to the summer of 2018. Here is one of my 1/8 mile passes a couple of months before camming the Camaro. I was lined up against a C5 at the local track. The only difference now was that I was running open headers instead of straightpipe. I don't have the slip anymore, but the et was 8.5@8?mph
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 Last edited by Chris49066SS; 06-02-2019 at 10:39 AM. |
05-31-2019, 09:02 AM | #14 |
Drives: 2010 2SS Coupe; 2011 2LT Vert Join Date: Dec 2018
Chris - Awesome build buddy. You are certainly the master at putting the right parts together to go very fast. That 60' and ET are incredible. I'll be following the build thread for sure! Hurry up with chapter 2!!! - Jeff
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
