Old 05-31-2019, 07:47 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Removing resonator
I have a 2010 SS automatic. Can I have the resonators cut out and replaced with pipes welded in and still retain the h-pipe portion? My muffler shop is really good at this stuff. I'm just confused, when I looked at pics online, it looks like this big resonator box engulfs the factory H-Pipe as well. I'm hoping to just have the resonator area/box cut out and then having piping welded in while retaining the h-pipe portion.
J.D
Maroon 6.2L SS is offline   Reply With Quote
Old 05-31-2019, 08:09 PM   #2
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
What is your end goal? The l99 resonator is big and as your said. ...incorporates a versionof an h pipe inside. You need a cross over of some type so your exhaust flows better.
rontammy0 is offline   Reply With Quote
Old 05-31-2019, 09:51 PM   #3
marklsx
Drives: 2014 Camaro 1SS
The resonators help to remove the odd drone caused by the AFM. If you are keeping the AFM you might want to keep the resonator. I say remove AFM and put in any exhaust you like. Also remove the AFM lifters. While you are in there put in a better cam. And install some LT headers and get a tune. I forget what the question was...
Just search on AFM and drone:
https://www.camaro5.com/forums/showthread.php?t=332699
2014 1SS - BTR Stg3, GMPP CNC Heads, Kooks LTs & cats, Magnaflow 2.5" Street w/Res X, Z28 CAI
marklsx is offline   Reply With Quote
Old 05-31-2019, 10:04 PM   #4
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
J.D
https://www.camaro5.com/forums/showthread.php?t=75846
This thread shows what's inside the resonator. No actual h-pipe inside. You would be better off to replace it with an x pipe as long as you have afm tuned out.
StingrayblueSS is offline   Reply With Quote
Old 05-31-2019, 10:49 PM   #5
rontammy0
Op you can also disengage afm with the paddles.
Old 06-01-2019, 02:41 AM   #6
Stubbsy
Stubbsy's Avatar
Drives: 2012 2SS RS
Magnaflow X Pipe
I removed the stock resonator and replaced it with a Magnaflow X pipe, I run long tube headers and hi flow cats, the rest of the exhaust is stock. I did not want it too loud.
Stubbsy is offline   Reply With Quote
Old 06-01-2019, 05:54 AM   #7
Nb1081
Drives: 10 2ss/rs
You can get a x pipe to go in there from summit or jegs for under 200
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 06-01-2019, 07:48 AM   #8
Maroon 6.2L SS
I thought it might save a little weight and flow better if I could cut it out and have a couple pipes welded in. I didn't think about the AFM or drone etc...No biggie, still learnin. I'm having L.Ts with cats installed in 1.5 weeks, can't wait for that. Currently have outlaw axle backs.
Old 06-01-2019, 08:28 AM   #9
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
If your doing long tubes you’ll want a tune anyway. Might as well disable AFM at the same time and pick up a mid pipe from jegs
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 06-01-2019, 09:19 AM   #10
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Some are going with the double helix(2 x-pipes in series) like Borla has I believe. An intriguing idea and with your muffler man should be a straight forward install. Looks like the scavenging affect could be just the ticket...no idea on how it sounds.
good luck!
Peace
Old 06-01-2019, 10:10 AM   #11
Bow94z
Drives: 2015 Camaro 2SS/RS
What magnaflow resonated X pipe does everyone use?
Does this have more noise over stock resonators?
2015 2SS/RS 6spd
Rotofab CAI,MGW Shifter, DSP Tune
Kooks LT/HFC/Xpipe/NPP Mufflers
4:10's, Trutrac
Solid Cradle Bushings, BMR Toe and Trailing arms
Bow94z is offline   Reply With Quote
Old 06-01-2019, 11:51 AM   #12
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Magnaflow 11386 is the 2.5" muffler with an x pipe inside. I would think it would be louder than stock, even with the rest of the exhaust untouched? If you have an L99 the rear mufflers are quieter than the LS3 mufflers so you still have to overcome that.
DSX_Camaro is offline   Reply With Quote
Old 06-02-2019, 11:06 PM   #13
flynhawaiianss
Drives: 2011 Chevy Camaro SS
Can get a stainless x pipe with clamps from Summit Racing or Jegs. I got mine from Summit for $140 I believe.
flynhawaiianss is offline   Reply With Quote
Old 06-02-2019, 11:13 PM   #14
radar1972
Drives: 2012 IOM SS/RS
I have a Range device I turn on each time I drive to defeat AFM.
How do you do it with the paddles?
radar1972 is offline   Reply With Quote
