Old 06-01-2019, 10:07 AM   #1
Jmc2011
Drives: Chevy camaro
Used atp tt kit question
I bought a used kit. While waiting for it to be shipped I’m trying to get all the necessary pieces for install. It came from a manual car and I am putting it on an automatic. Was wondering if anyone knew of anything that I might need to complete the install
Jmc2011 is offline   Reply With Quote
Old 06-01-2019, 11:57 AM   #2
FieroItaliano85
Drives: 2014 2SS/RS L99
You will need the AGP trans lines too. I have some for sale, I only installed them and decided to upgrade the torque converter, so I just put a trans cooler on instead to reduce all the heat added with the converter. PM me if you’re interested in saving some cash.
2014 2SS/RS AGP Twin Turbo
FieroItaliano85 is offline   Reply With Quote
Old 06-01-2019, 04:25 PM   #3
TITANSFAN
TITANSFAN's Avatar
Drives: 1970 Pontiac Firebird L8T
So if you run a trans cooler, you don't need the AGP lines? I have an M6 now, but might change that out down the road.
TITANSFAN is offline   Reply With Quote
Old 06-02-2019, 12:42 AM   #4
NABeastRR
NABeastRR's Avatar
Drives: Camaro
You don't need AGP trans lines, I made my own and would advice you do too. Only part of the kit that sucks.couple AN fittings and hose and your good.
15 Camaro 2SS/RS
13.3@106 100% stock
12.0@114 VR-DRX/RCR manifold/BW stg2 TB/2"ARH w cats/3"Corsa extreme/Fasterproms tune/MT Street R
AGP TT build in progress
NABeastRR is offline   Reply With Quote
Old 06-02-2019, 11:47 PM   #5
scotty9794
Drives: 2011 ss/rs
I suggest hardlines. I guess my situation is a little different as i have a 4l80 in my car, but rubber lines barely cleared the little gap between the turbo and bellhousing. Steel lines removed the concern. Had a rubber line get burned previously. They go to rubber at the front of the oil pan well away from heat.
TMS forged 376, 237/239 cam, AGP kit w/ s256 twins and race intercooler, Alky dual nozzle meth system, FIC 127lb injectors, Fore dual TI 450s, Jakes stage 4 4l80e, Circle D triple disc billet 3400 stall, DSS aluminum shaft, eBoost 2 controller, BMR toe rods-adj lower control arms-adj trailing rods, and bushings, nt555r rears.
scotty9794 is offline   Reply With Quote
