Old 06-01-2019, 11:06 AM   #1
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
New PB - Cam only M6 4160lbs into the 11s finally
Hey guys - I finally punched my 11 second ticket last night. I have really had to mentally retrain myself to let the car RPM enough on the launch to get this thing down into the low 1.7x range in the 60', but leaving with 5500-6000rpm is dead hooking and the times keep improving.
The first three passes I struggled with rolling out of the beams too gently and was cutting 1.8-1.9 short times and low 12's. Fourth pass I went up and told myself I wasn't leaving with less than 6000rpm, and I wasn't going to dilly dally around with a long drawn out clutch release. Bam - 1.733 going on to a 11.87@117. I tickled the limiter on the 3-4, probably left half a MPH on the table.
Back up 40 minutes later, tried the same thing, another 1.74, 7.68 in the 1/8th, and then missed fourth. Definitely was on it's way to another 11.
Last pass of the night, same thing, send it on about 5800rpm with a quick deliberate release, cut a 1.73 and on to a 11.86@117. Track prep was awesome, I don't think I did more than baby bird chirp the tires once on the hit.
I think next steps for me are to get on to a smaller tire, that 29" is just too tall. I think a 25.5" tire will leave harder and it'll definitely make more MPH out the back. But, it's a nice start to the season.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 06-01-2019, 11:35 AM   #2
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Nice run Andrew! That thing sounds awesome!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 06-01-2019, 11:43 AM   #3
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
WOOO HOOOO!! Nice driving, Andrew! I'm very impressed with how your car leaves. Very cool!
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 06-01-2019, 12:07 PM   #4
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
Great hit and congrats on the PB!!
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 06-01-2019, 01:44 PM   #5
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 06-01-2019, 02:04 PM   #6
vinman
The BBOMG fill-in husband
vinman's Avatar
It's that new ceramic coating adding to your aero Good job buddy!
UPSTATE C5 MEMBER
Old 06-01-2019, 10:04 PM   #7
acammer
acammer's Avatar
Thanks guys - that was really the season goal, to break into the 11s. So now I gotta figure out what's next - more like what I can afford.
Old 06-02-2019, 06:09 AM   #8
Jayjellyfish212
Drives: 2014 1LE
I have some 3” muffler deletes in the garage that would delete those heavy suitcase’s I was gonna use on my car until I went with a system that included the muffler delete section. The only issue I think would be they have dual tips so not sure how it could work with your rear exhaust body panel openings. Would reduce weight in the rear dramatically though and help drop some time off.
Honestly I think your about due to start working on getting a drag pack on the car with how well your time is and how good the car is working now.
Old 06-02-2019, 11:15 PM   #9
Dbunch9
Nice man thats awesome!!
Dbunch9 is offline   Reply With Quote
Old 06-03-2019, 07:38 AM   #10
acammer
acammer's Avatar
Hmm - that's tempting. I like the idea of being able to close up my cutouts once and a while and still have it quiet, but I bet there is at least 40lbs of mufflers hanging back there that I only use about 2x a year for 5% of my total miles driven. Might be time to stop managing to the exception and get it done.
You're right about the drag pack - that's a definite next step. There is 100+lbs of rotation mass I could drop if I had a dedicated drag setup - and that alone is worth a lot. Additionally, I could go down to a 25.5" tire, and I really could use all that extra gear ratio.
I listed my ZL1 18x11's for sale, if those sell maybe I can start with getting some 17" rears with a 275/40, and then get the skinnies down the road.
Old 06-03-2019, 03:54 PM   #11
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Nice work Andrew!!!
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 06-03-2019, 05:08 PM   #12
Nb1081
Drives: 10 2ss/rs
Nice job and its 23.6 pound reduction from stock mufflers to an mbrp delete thats using bathroom scale but every ounce counts i think removing back seat is good for 40ish
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 06-03-2019, 05:28 PM   #13
acammer
acammer's Avatar
Good info on the mufflers. Not as much as I had hoped. I read the passenger and rear seats is 88lbs. 2-300lbs off the car would make a phenomenal difference - that with the gear ratio change would probably nudge it into the mid low 11s.
Old 06-03-2019, 05:40 PM   #14
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Nice pass......get a 100 shot.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
