![]() Drives: 2010 SS/RS & 2017 SS/RS Join Date: Jan 2009
Camaro is getting Multiple codes
P2534
P3449 P3441 P3425 P3401 P069E P0102 Please help me someone |
Runs poorly feels like a bad miss fire any help yet guys?.?
2010 V8 Auto. Could it be something with the DOD or AFM
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro SS/RS - 2004 Silverado Join Date: Mar 2010
I assume you already looked up the codes. If not, here's what they mean:
P2534 - Ignition Switch Run/Start Position Circuit Low P3449 - Cylinder 7 Deactivation/Intake Valve Control Circuit P3441 - Cylinder 6 Deactivation/Intake Valve Control Circuit P3425 - Cylinder 4 Deactivation/Intake Valve Control Circuit P3401 - Cylinder 1 Deactivation/Intake Valve Control Circuit P069E - Fuel Pump Control Module P0102 - Mass Air Flow Circuit Low I'm no expert but you have a bad electrical connection, bad ground, or battery issue. Has there been any electrical work on your car recently? Any work under the hood recently? Check fuses/relays in the fuse box under the hood and the fuse panel inside dash on driver's side.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80 2004 Black Silverado 1500 2WD Regular Cab, Short Bed -5.3 LM7, 4L60E, 3.42, G80 2014 White Caprice PPV -6.0 L77, 6L80E, 2.92, G80 |
![]() ![]() Drives: 2010 SSII w RS & Sunroof Yellow Join Date: Aug 2009
Location: West Suburbs of Chicago, in a Courthouse Somewhere
I second that thought.
Change the Battery then check the grounds. |
#6 |
376 cubic inches of fun
#7 |
Rockin' Steady
Drives: 2010 Camaro 2SS Join Date: Apr 2012
This message board needs to stop recommending a battery replacement and checking grounds and battery connections for every drivability related concern, it’s making people waste money on repairs for their vehicle that it may not potentially need.
I would say the rough running condition would definitely be related to the AFM/DOD DTC’s. Have you modded the car at all? The AFM related DTC’s are common on our pickups with that generation engine, most commonly we find a fault within the AFM/DOD solenoid valley plate assembly. The MAF DTC and ignition switch DTC i would asses after the rough running condition is repaired, I would assume the MAF DTC will pass after the engine runs fine again. P069E is a dummy code because of the issues your having with your car.
Eric Carrier, proud GM Technician for over 10yrs.
2010 Camaro 2SS Black, L99, SLP headers, GMPP axle back, complete JRE tune, 22" Boss 337's, Nitto Invos 5% tint, Eforce Supercharger w. 3" pulley, ADM FPCM, ID850's, JRE fuel rail mod, Eforce CAI, Moroso catch can, spark plug insulators. |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I'm not sure how recommending checking battery, grounds and battery connections is wasting money. You got to start somewhere and this doesn't really cost anything. If you have several seemingly non related codes, that's where I would start. If the battery in a 2010 is original, replace it anyway before it causes problems.
#9 |
Inspecting battery connections costs NOTHING.
Checking the battery costs NOTHING. Any time someone with a 9 year old car reports error codes, low voltage/weak battery is the first thing to question. In my experience, built-in tests generate a lot of false errors due to low voltage, so it's a no brainier for me to look there first. But also, anyone reporting error codes here should state up front any mods or accessories, because they could be the cause of spurious error codes. |
#10 |
Rockin' Steady
Checking the battery’s state of health and condition is very different from the suggestion above that clearly states to replace the battery and inspect grounds. A failing battery or loose improper connections does not cause AFM/DOD issues for certain cylinders and cause nothing else but one low voltage, ignition switch DTC. If you have 1 low voltage DTC that is passed history vs several failed current DTC’s that are evidently the reason why the car is running rough you start with the failed current DTC’s and work you way down the list.
I’ve been doing this long enough for GM to tell you that I know their diagnostic flow charts/symptoms and DTC’s for battery/voltage related issues and this vehicle is definitely not exhibiting these conditions even if i’m reading this on a message board.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
It would be helpful if the OP would respond to the thread they started 10 days ago. Lot of unknowns.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
#12 |
Thanks. Battery checked out good. Changed valley plate as well still having the same issues. No mass on the vehicle at all also
#13 |
*mods
#14 |
ECU?.?
