Old 06-01-2019, 07:17 PM   #1
gsxrturbo
Drives: 2010 ss
1 piece driveshaft viberation
do 1 piece driveshafts vibrate at high speed,140 plus..I have a dss 1 piece Harley davison edition driveshaft vibrates bad at 140 plus,anyone else have that problem,they already sent me the longbox edition way to long,got it bad and thing acts like it wants to go to mars!!! anyone
gsxrturbo is offline   Reply With Quote
Old 06-01-2019, 08:16 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
I have the CF version and it has been rock solid. 4 years going!
-Don
747 RWHP 794 RWTQ
Old 06-02-2019, 06:59 PM   #3
gsxrturbo
Drives: 2010 ss
anyone else have any problems!!!!!
Old 06-02-2019, 07:19 PM   #4
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
It may need to be rotated on the u-joint. Contact DSS, they should help you out.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 06-02-2019, 09:57 PM   #5
Bo White
Bo White's Avatar
Anyone thats ever measured the angles of these drivetrains know why GM put a 2 piece driveshaft in them.
Old 06-03-2019, 05:09 PM   #6
gsxrturbo
Drives: 2010 ss
they had the driveshaft marked where it needed to be,wonder with the 3.91 gear that shaft spins alittle fast at 140
Old 06-14-2019, 11:24 AM   #7
600hp-lpe
Drives: 2010
I have the CF 1 pc driveshaft - no vibration at speeds 130+
P.S. - I have 3.73 gears. M6 manual trans
600hp-lpe is offline   Reply With Quote
Old 06-14-2019, 12:48 PM   #8
Nb1081
Drives: 10 2ss/rs
Thats what the offset bushing or trying to correct arent they?
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
Old 06-14-2019, 12:52 PM   #9
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
I took out my DSS aluminum one peice and put the factory one back in. It made a lot of noise and vibrations. It is much more quiet and I can't tell the difference between the 1 and 2 piece. Yes, I installed it correctly.
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-14-2019, 10:12 PM   #10
Bo White
Bo White's Avatar
Those are for lowered vehicles to realign the axles.
Old 06-15-2019, 10:56 AM   #11
gsxrturbo
Drives: 2010 ss
talked to dss,they don't want to do anything about the problem,they say my car is the problem,my car has 17000 miles on it and I know it has never been wreaked,so thinking on getting it balanced myself.so much for a warranty!not happy at all
Old 06-15-2019, 11:37 AM   #12
Black_SS10
SomeguyK
Black_SS10's Avatar
Yea, I'll never buy anything from DSS again.
More to come.
Old 06-24-2019, 12:19 AM   #13
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
Gforce dumped dss stuff way better built
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
