Old 06-03-2019, 04:59 AM   #1
Bfh_american
Drives: 2013 Camaro 2SS
700 RWHP Build question
Afternoon Gents. I have a question. I'll be SCing, camming, etc my 2013 2SS Camaro. With that added power, 700 +- will the rear end need to be changed? I've been debating this with a friend, and would like another opinion.
Bfh_american is offline   Reply With Quote
Old 06-03-2019, 07:08 AM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Some have rans 9’s with the stock SS rear. Depends on what your plans are with the car. 700hp your not going to get traction with stock wheels/tires. If smoking tires till 80mph is the goal then the stock rear/axles might survive. If you add a decent rim/tire and get traction then they may not.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 06-03-2019, 07:19 AM   #3
Bfh_american
I'm not really gonna be doing any track racing/ dragging any time soon. Just gonna be on the roads/ pleasure car. Tires are gonna be good quality, but I'm not gonna be doing anything out of the norm. What would you recommend if I do upgrade?
Old 06-03-2019, 07:25 AM   #4
Omega
Drives: G8
If you address everything you need to to eliminate wheel hop, you will be fine.
Sent from my Pixel XL using Tapatalk
Omega is offline   Reply With Quote
Old 06-03-2019, 07:37 AM   #5
Bfh_american
Wheel hop, essentially the car losing and gaining traction over and over again. So, the remedy is either better tires or bushings, right?
Old 06-03-2019, 10:07 AM   #6
10aSSee D
10aSSee D's Avatar
Drives: Silver 2010 SS Camaro
I’m running G-force 9 inch and axles along with BMR suspension. I had Nittio NT-05 tires and would just blow the tires off through 4th gear. I switched to Mickey Thompson street ss drag radials and man do they hook!
MODS:
Old 06-03-2019, 10:15 AM   #7
Bfh_american
🤔 Gonna look into those tires for sure. Ordering some within the next monthk
Old 06-03-2019, 11:35 AM   #8
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
for wheel hop, you will want cradle bushings toe rods and trailing arms, LCA's wont hurt either. if you put 700 to the wheels and run street tire....you will be fine, but the power will be wasted because you will constantly spin the tire from a dig. If you run a drag radial....it will be Russian roulette with the diff. If you upgrade, I would go the ZL1 diff. that should easily be good for 1000rwhp.
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 06-03-2019, 01:23 PM   #9
Omega
Drives: G8
Yeah, the bushings and upgraded arms reduce the chances of wheel hop when you break traction. Better tires reduce the wheel spin. Upgraded axles withstand the higher TQ load of the sticky tires and can survive wheel hop a lot better.
Old 06-03-2019, 02:39 PM   #10
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Autos happen to be easier on the diff than the manuals (less shock). Like others have said here, some suspension work - at minimum swapping trailing arms and toe rods will reduce the wheel hop. Your stock axles will be the first to go. If you realize you need a stronger diff, the ZL1 is a great option being the best bang-for-the-buck. That includes the OEM ZL1 axles as well. The OEM driveshaft should handle your needs.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 06-03-2019, 02:46 PM   #11
Bfh_american
Thanks gentlemen!
Old 06-04-2019, 03:00 AM   #12
Bfh_american
I read awful reviews on the MT STREET SS. They really hooked for you? I'm looking at Toyo R88Rs now. They seem like they have the most hook. Not crazy expensive either.
Old 06-04-2019, 06:36 AM   #13
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Don't know about the M/T SS but check out the M/T ET Street Radials
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 06-04-2019, 01:09 PM   #14
10aSSee D
10aSSee D's Avatar
MT street radials are the ss tires I believe. I’m telling you they hook!! I was amazed by how well they took to the street. I went from blowing tires off to straight traction. I highly recommend these tires.
MODS:
