Old 06-03-2019, 06:13 AM   #1
Wolfee
Drives: camaro / santafe / excel
Question Camaro 2010 HORN
Hey All
does the camaro 2010 have a relay for the horn and if yes where it's location ?
anyone have Horn Wiring Diagram ??
Wolfee is offline   Reply With Quote
Old 06-03-2019, 06:19 AM   #2
fhrex
Drives: 2011 Camaro 2LT/RS
relay is in underhood fuse block
fhrex is offline   Reply With Quote
Old 06-03-2019, 10:29 AM   #3
Wolfee
Man I only found a Horn Fuse ( Fuse 51 Horn ).. am looking for the relay if there is one for the horn
Old 06-04-2019, 06:09 AM   #4
fhrex
Old 07-03-2019, 07:30 PM   #5
JJPlace1
JJPlace1's Avatar
Drives: 2010 2LT Victory Red
I am having an issue with my horns , neither work . There is no relay in the fuse box under the hood. I checked the fuse and it has only 11 volts but all other fuses have correct battery voltage which is 12.6 volts . I checked all fuses under hood and inside vehicle and none are blown . Could it be the horn switch in the steering wheel? Any suggestions or anyone have this issue. [B]I checked and double checked and there is no relay for the horn in the fuse box under the hood. [/B]
Previous Vehicles
1970 Impala 2D 350/300
1972 Buick GS 350
1967 Pontiac Firebird 326
1969 Chevelle SS 396/375 I really miss this one
1966 Chevelle SS 396/350
1978 Plymouth Fury 440
1982 VW Scirocco ( Got married )
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
JJPlace1 is offline   Reply With Quote
Old 07-07-2019, 01:55 PM   #6
JJPlace1
JJPlace1's Avatar
This is probably going to be in the BCM because the panic button on the remote works , lights flash but no horns !!
Previous Vehicles
1972 Buick GS 350
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
Old 07-07-2019, 01:57 PM   #7
JJPlace1
JJPlace1's Avatar
Whats posted above as far as wiring diagram is whats in Mitchell On demand. I have access to that and it is NOT CORRECT for the horns.
Previous Vehicles
1972 Buick GS 350
1987 VW Scirocco
1992 Ford Taurus V6
1996 Dodge Intrepid
2002 Dodge Intrepid
2002 Mercedes ML500
2010 Camaro 2LT
Old 07-18-2022, 01:17 PM   #8
chukky
Drives: Chevrolet Camaro
I have same issue alarm doesn't beep, panic works but no sound, steering wheel doesnt work either. The horn fuse is good, I doubt it's a bad horn... anyone know if there is a horn relay somewhere??
chukky is offline   Reply With Quote
Old 07-19-2022, 10:31 AM   #9
NOT A 45
NOT A 45's Avatar
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3
It's built into the under hood fuse block and isn't replaceable. You have to replace the entire fuse block. The fuse is after the relay, so a easy way to check would be to use a jumper from battery voltage to the fuse and see if the horn blows. If not you need horns.
NOT A 45 is offline   Reply With Quote
Old 07-19-2022, 10:35 AM   #10
NOT A 45
NOT A 45's Avatar
11 Volts while pressing the horn button? There's your problem.....the relay contacts are burned. You need a under hood fuse block.
Old 07-19-2022, 10:37 AM   #11
NOT A 45
NOT A 45's Avatar
Originally Posted by Wolfee View Post
Hey All
Yes it has a relay that's built into the under hood fuse block and isn't serviceable.
