Anyone have a stock ride feel on coilovers. Who has them?
Who's got them? who can set me up with the right person or manufacturer. thanks
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
![]() Drives: 2 2014 SS 1LE, 2010 Nissan Titan Join Date: Jul 2018
I'm loving my ridetech HQ's
Pedder's are another great option. I went through RDPstore, they're a vendor here and very helpful by phone or email. You'll be able to get stock ride feel with any decent coilover setup as they are very adjustable. I have my Pedders set very firm but even with the added damping it's not harsh.
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Ridetech HQ’s hands down. Pedders supercar and regular Pedders or BC Racing are either to bouncy or to stiff. Had supercars, which are double adjustable for four years. Could never get them the way I liked. Valving wasn’t done well and The spring rates are to stiff for the valving. More designed for racing on a road course.
Ridetechs you can get whatever spring rates you want for your purpose. Note any coilover will be more firm then stock because of the higher spring rates, but Ridetechs were made for the Camaro so the tide is very good. Call JDP and they will set you up |
#5 | |
#6 | |
#7 |
SS
ride tech here also great ride for sure the solid metal upper bearing mounts transmit a few road impacts but the noise is not bad for the performance, get ready for some serious cornering
CCW sp16a track set, BTR stage 3 cam and kooks longtubes with high flow cats
#8 |
![]() Drives: 2010 2SS/RS Join Date: Jul 2014
I have used the ridetech as well and ride was really good. Could get them fairly soft and the valving could handle it.
Only set up I used that I liked better was Detroit speed, but they are twice the price.
Current car
2011 Backdraft RT3 427 stroker (DART block/ forged internals/ AFR 205 Aluminum heads/ Quickfuel 750) 600hp/590ftlbs, wilwood brakes, custom JRI double adjustable shocks. Weighs in at 2300 lbs.... Use to have 2010 Camaro SS - ECS SC 1500, Kooks LTH + HFC, Corsa, CTS-V brakes, Detroit Speed Coilovers, BMR sways (FE4 conversion), DSE endlinks, BMR toe rods and trailing arms, Forgestar F14's |
#9 |
Yeah, set them all to 20 clicks from stiff, softest useable setting and cruise in comfort down the freeway. You only feel a few soft hits from bumps from the springs
