Old 06-04-2019, 04:15 PM   #1
Trickskier
Native Floridian
Trickskier's Avatar
Pennzoil Ultra Platinum
What's everyone's take on the new Pennzoil Ultra Platinum made from Natural Gas instead of crude oil? Better than other synthetic oils like Mobil-1, Royal Purple, Valvoline, & Castrol?
Old 06-05-2019, 11:22 AM   #2
gtstorey
My first guess without any real basis is that it's probably not much difference in performance, probably cheaper to make.
Old 06-08-2019, 12:05 AM   #3
Blakk11SS
Blakk11SS's Avatar
Drives: 2011 Camaro 2SS/RS
I gave it a try (2x) in my SS a while back. The engine did not like it. I returned to Mobil1 and all was good again.
Blakk11SS is offline   Reply With Quote
Old 06-08-2019, 03:47 PM   #4
Gstick
Drives: 2015 Camaro SS/RS 1LE
I can't find the "Ultra Platinum" anywhere in sw, PA. But the "Platinum" is all I have been using and my 6.2 engine seems to run great on it.
Gstick is offline   Reply With Quote
Old 06-08-2019, 04:25 PM   #5
DavidtheM
DavidtheM's Avatar
Drives: 2014 Camaro 2SS 1LE
How so?
DavidtheM is offline   Reply With Quote
Old 06-10-2019, 05:36 PM   #6
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
My engine runs it without issue.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 06-16-2019, 10:38 PM   #7
Blakk11SS
Blakk11SS's Avatar
Originally Posted by DavidtheM View Post
How so?
The Pennzoil needed changed at a much shorter interval and was looking really thin and dirty. Whereas the Mobil1 held up better and ran for a longer interval and did not get so thin. I believe oil performance varies depending on its base stock. My valves made much more noise with the Pennzoil too from what i recall.
