Old 06-06-2019, 08:42 PM   #1
BUBZ28
BUBZ28's Avatar
Drives: '15 Z/28 #0270
Stahlbus Oil Drain Valve
Anyone have experience with these?
Did an oil change today and a concern popped up. I have 2 of them. The main drain valve and one near the oil filter. The main drain valve had a small amount of oil (about 5ml) within the dust cap the other valve was completely clean and dry. No leaks between the pan and valve's.
Last oil change was this time last year and 3-4k miles of mild to aggressive (mostly mild) street use.
Is the small leak a concern?
Are these a wear item and should they be replaced periodically?
Should they not be in place for track use?
That said they worked great. Drained both simultaneously directly into the waste jug. No mess from the second drain valve with oil all over the cross member. Space was a little tight between the valve and that heat sink looking thing but workable.
BUBZ28 is offline   Reply With Quote
Old 06-06-2019, 09:00 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
My neighbor uses an oil drain value on his 4x4 truck. Replaces it every 5 years or so. He seems to like it.
Vegas Bound is offline   Reply With Quote
Old 07-23-2019, 01:15 PM   #3
Hooks112
Drives: '15 Z/28 #698(A/C,AW) & other stuff
Resurrecting this post...
Hoping that someone else can chime in on their experience with this product. Seems a great idea and a time-saver. Not sure about the leak mentioned here.
Seems like Hammdo recommends it in other posts - Don, any updates on your use of this product??
Anyone else using something similar/better?
https://www.amazon.com/Stahlbus-Drai...b_b_asin_title
Thanks
Hooks112 is offline   Reply With Quote
Old 07-23-2019, 02:04 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Yep... Like the fact the drain plug is installed and not removed...
Prior to this, I replaced the o-ring every time. I have a lot of those 12mm o-rings ;o)
-Don
747 RWHP 794 RWTQ
Old 07-23-2019, 02:34 PM   #5
Hooks112
Sorry for calling you Jon, Don - I knew better, but my fingers didn't...
Thanks for the info - I seem to love hoarding 12 mm o-rings as well...
Old 07-23-2019, 02:46 PM   #6
hammdo
hammdo's Avatar
All good.
2k miles since change and all is well - including trip to CFest. I like this one best as it's really out of the way and no 'Valve' can break while racing...
-Don
747 RWHP 794 RWTQ
Old 07-23-2019, 05:52 PM   #7
Hooks112
Just to confirm, the 12 x 1.75 is the correct unit??
Old 07-23-2019, 07:36 PM   #8
hammdo
hammdo's Avatar
https://www.camaro5.com/forums/showp...postcount=2524
Has the link...
-Don
747 RWHP 794 RWTQ
Old 07-24-2019, 11:59 AM   #9
BUBZ28
BUBZ28's Avatar
Yes
