![]() Drives: 2010 Camaro SS A6 Join Date: Oct 2018
Spark Plug Wires
Can anyone recommend a good set of spark plug wires for a 2010 Camaro SS Automatic? I've got most bolt-ons, and am getting headers put on this week. I figured I better upgrade to better plug wires. I'm doing some bracket drag racing over the summer. I tried to search online myself and got overwhelmed. Trying to keep it under $75
Thanks |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
The stock wires work just fine.
More to come. |
![]() Drives: 2012 2SS Victory Red convertible Join Date: May 2016
My Taylor wires have held up great since my header upgrade. Plus they come in different colors to add some bling under the hood. I also put color matching heat socks over the wires for added protection.
![]() Drives: 2013 Camaro SS Join Date: Oct 2016
Taylor are the best for your buck. Coming in right at $75 that's your best option. I have ran them for over a year without issue.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Black & Silver Join Date: Aug 2010
I installed Taylor wires after adding headers also. Two years and no problems.
STAINLESS WORKS HEADERS-TUNED BY JANNETTY RACING-C.A.I. INTAKE-TAYLOR 409 WIRES-SOLO AXLE BACK EXHAUST-ELITE CATCH CAN |
#6 |
USA-1
Stock, but I would grab some wire sleeves off Amazon/Ebay just to protect them from the temps.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
#7 |
I also run Taylor wires. You want to get wires with the least amount of resistance When I bought mine (3 yrs ago) they were the lowest.
Lusinda 2010 2SS/RS |
#8 |
Drives: 2011 2SS/ RS INFERNO ORANGE L99 Join Date: Dec 2012
MSD Super Conductor plug wires on my fbo l99. Work well and look great.
#9 |
![]() Drives: 2014 2-SSRS Slushbox Join Date: Sep 2018
I went with these from Summit Racing. Didn’t notice a bit of difference though.
Sorry for double pic |
#10 |
Submarine Pilot
Drives: 2015 Commemorative Edition SS Join Date: Jul 2018
Taylor Thundervolt 10.4. Only comes in black, part 98003. Same as all the other thundervolt wires except it has a thicker silicone shell. I love them. Had them on and off several times and they still lock on tight.
2015 Commemorative Edition 2SS/RS [L99] -Black-
|GPI: Tune, Rod Mod, PTB; Vararam Intake; ARH 1_7/8 headers & 3" cat-back; GM 3.91 gears; Circle D 4c converter and trans rebuild; Derale trans cooler; B&M deep trans pan; JMS Pedalmax; Taylor Thundervolt 10.4 wires; NGK Ruthenium plugs; 160 tstat| |
#11 |
![]() ![]() ![]() ![]() Drives: 15 Camaro SS Join Date: Oct 2018
msd here as well. I'm happy with them
#12 |
i was referred to to PCM of NC but there may be out of your budget you said. but i think they are worth it.
http://www.pcmofnc.com/product-categ...wires-socks-2/
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
#13 |
![]() Drives: 2SS/RS LS3 NPP Join Date: Feb 2018
Been using the Taylor .409 wires since 1996, never had any trouble.
Taylor 409's, BF Comp 2's, Z26 pads, Hurst billet shifter
#14 |
Instagram: Sangstah
Taylor 409 with my Kooks here
