06-11-2019, 10:52 PM | #1 |
Drives: 2015 camaro 2ss Join Date: Nov 2017
6l80e over rev 1-2 shift
How do i go about changing/ lowering my shift point/timing between 1-2 shift? while i was at the track every run bounced off the rev limiter between the 1-2 shift and im not sure if its the trans going or if its in the tune. any ideas or help where to change it?
06-12-2019, 09:26 AM | #2 |
Instagram: Sangstah
Get a SCTx4 tuner and hit up RDP, they can tune your trans shift points
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
06-12-2019, 09:28 AM | #3 |
06-12-2019, 10:03 AM | #4 |
Drives: Fastest 2010 Camaro V6 Join Date: Apr 2010
Lower your RPM and MPH in the full throttle shift speed and shift RPM tables. You want it to start early enough to where the clutches will be full and ready when you hit the desired shift RPM.
06-12-2019, 11:15 AM | #5 |
8.60 @ 157 @ 4200lbs
Agree with magnumforcegb on his statement and also find that mph and shift rpm sometimes are to close to each other. What your mods to car
06-12-2019, 12:06 PM | #6 |
It has a LY6 on 7 pounds from a vs racing 7875 billet turbo (going 14 this weekend) BTR stage 2 turbo cam and Cirlce D 4c stall. Fuel system is Deautchworks DW400 pump snake eater performance 1000cc injectors Cooling system is mishimoto rad with 160 thermostat lsx innovations 6lmani6an trans adapter to big cooler
06-13-2019, 12:44 PM | #7 | |
Employ one of our Calibrated Dipstick tube kits and service the trans with a highflow filter. Ted.
www.jannettyracing.com
06-13-2019, 12:46 PM | #8 | |
already have one your dip stick tubes although i did not know about a high flow filter for these trans. where do i go about buying one? Thanks! |
06-13-2019, 12:48 PM | #9 |
Give us a call we stock them.
06-13-2019, 11:02 PM | #10 |
07-22-2019, 11:24 AM | #11 |
Drives: 2015 2SS Stock Join Date: Sep 2018
Janetty Racing,
In refrence to your trans Dipstick tube, on your site it says " a must if you have your engine and trans out." So are you saying i have to take out either my motor or trans to put the tube in?
2015 2SS auto. AGP twin turbo, LS9 cam, BTR 660 springs, LS9 Gaskets, ARP studs, 400lph UPP fuel system, MBRP XP 3” cat back, 305/30 Micky Thompson Sport comp tires. 12” Fockford fosgate P1, Rockford Fosgate 600w amp.
07-22-2019, 11:28 AM | #12 | ||
07-22-2019, 11:35 AM | #13 |
My mistake, it was from a customer review. Great video, ordering mine now.
