Old 06-16-2019, 06:18 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Stock manifolds
Does anyone know how much weight you will save when swapping out stock manifolds/cats for long tube headers/cats?
Maroon 6.2L SS is offline   Reply With Quote
Old 06-17-2019, 10:46 PM   #2
CHRISCAM
CHRISCAM's Avatar
Drives: 2013 Summit White 2SS/1LE
I doubt you would save much, if any weight by going with long tubes. If anything, they might actually be heavier than the stock manifolds.
Think about how much more metal is involved in making the long tubes vs. the short runners on the stock manifolds. Yeah, the stock manifolds are thicker, but long tubes are like 4-5 times as long in the runners vs. stock manifolds.
CHRISCAM is offline   Reply With Quote
Old 06-17-2019, 10:52 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
The stock manifolds are iron aren't they? I remember them being pretty heavy compared to my headers, but that was a while ago so I may be mistaken.
InFiD3ViL is online now   Reply With Quote
Old 06-17-2019, 11:13 PM   #4
fly2hip8
Drives: 2013 Camaro 2SS
My guess would be between 20-30lbs weight savings
fly2hip8 is offline   Reply With Quote
Old 06-17-2019, 11:48 PM   #5
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
The stock manifolds are iron aren't they?.....
Yes they are....and a bit more than 20lbs heavier than a set of longtubes.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 06-18-2019, 06:30 AM   #6
Bo White
Bo White's Avatar
I have headers and manifolds at home. Ill weigh them when I get there.
Old 06-18-2019, 06:51 AM   #7
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
IIRC I dropped about 14 - 16 pounds but that is catless
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 06-18-2019, 07:02 AM   #8
Bo White
Bo White's Avatar
Long tube headers 26.6lbs
Factory manifolds 23.2lbs
Headers have 145k miles on them.
Manifolds have 10k miles on them.
Old 06-18-2019, 07:08 AM   #9
Bo White
Bo White's Avatar
Maybe someone has some cats to weigh. I dont have mine handy.
Old 06-18-2019, 09:00 AM   #10
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
I have some cats... I'll go weigh them now
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 06-18-2019, 09:19 AM   #11
PepeLePew
PepeLePew's Avatar
Bo - was the weight you listed per manifold or was it for the pair? My scale isnt the most accurate so I am not sure if I am in the ballpark or not.
I got 44lbs for both manifolds and cats all together. 13lbs for each manifold and 9lbs for each cat pipe.
I used my crappy scale to compare when I did the swap to TSP 1 7/8 long tubes with offroad pipes at that time I came up with only 8lbs saved. Even if my scale isnt accurate, I cant imagine it being more than the 15lbs Lazer recalls though.
Old 06-18-2019, 10:06 AM   #12
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
Maybe it is because the weight is distributed out further, but the stock manifolds felt WAY more heavy than my long tube headers. I was thinking that my headers combined felt as heavy as one stock manifold.
Check out my build thread
Old 06-18-2019, 11:52 AM   #13
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
stock manifolds with cats are heavier. Im guessing around 20-30 lb different like others have stated
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 06-18-2019, 12:01 PM   #14
lazerlemonta
Drives: 2010 C6 1LT
That is what i recall. People think it is a great weight savings but 4 primaries the whole legth of the header is heavier then the the small cast manifold. The only way to save a decent amount of weight is cat less mid pipes. My tri y headers on the C6 saved me 24 - 26 pounds because they are shaped more like a mid length header.
Best MPH 134.82
