Old 06-18-2019, 05:14 PM   #1
CamaroEMC
Drives: 2010 Camaro 2SS/RS
How do I check lifters?
Spent last weekend racing my 2SS at Road Atlanta. No major issues except my clutch pedal getting sticky at times when really hot.
Long story short, I have a noise that sounds like a header leak (whoosh?) at higher RPM, but more of a knock/tap sound at idle.
Thinking maybe a lifter? Or maybe a header leak, but not sure what would have caused that, since it has been fine on many other track days.
Oils temps at times were close to 300, so maybe oil can be the culprit.
My plan is to do an oil change, then listen for the noise. If still there, I want to pull the valve cover off and investigate further. Beyond looking at the springs, rocker and push rods, how can I check for a bad/stuck lifter?
2010 Camaro 2SS/RS
BMR Subframe connectors
BMR front and rear swaybars
BMR SPrings with Koni V2 shocks
TSP Cam build tuned to 482 rwhp
CamaroEMC is offline   Reply With Quote
Old 06-20-2019, 09:39 PM   #2
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Look for a loose rocker or a broken spring. Other than that,pull the heads and replace the lifters if nothing obvious jumps out at you from pulling the valve cover. 300 degrees is some pretty hot oil.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 06-21-2019, 02:22 PM   #3
CamaroEMC
Ya, I think it peaked at around 275-280 for oil temp. I changed the oil, and the noise persisted. I will be pulling valve covers today. Here's hoping for a loose rocker.
If I have to pull the heads, and replace a lifter, should I do all of them? Or just the faulty one? I really hope that if a lifter stuck, that it didn't wreck my cam.
2010 Camaro 2SS/RS
Old 06-21-2019, 06:01 PM   #4
eLeSthree
Drives: 2011 Camaro SS 6sp
OEM lifters are only $100 per set. Might as well replace all the lifters on that head at least. A collapsed lifter won't wreck the cam, but a crushed lifter wheel might.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 06-21-2019, 09:16 PM   #5
BigMatt
BigMatt's Avatar
Yes change them all if pulling the heads. Also send the heads out to be ported while they're off.
