Old 06-18-2019, 10:54 PM   #1
SS 310H55A
Drives: 2014 Camaro SS
Do REAR Bilsteins have internal bump stops?
I just got a new set of Bilsteins and am confused about the bump stops. The instructions for the front struts say the bump stops are internal and not to reuse the stock ones. The instructions for the rears mention nothing about bump stops. Do I reuse the stock rear bump stops and dust boots with the rear Bilstein shocks?
2014 SS | MGW Flat Stick shifter | Raceseng Slammer shift knob | Z/28 spoiler and grill
SS 310H55A is offline   Reply With Quote
Old 06-19-2019, 10:57 AM   #2
Matty Ice
Matty Ice's Avatar
Drives: 2015 SS/RS 1LE
I did not use bump stops on the rear with mine. I think per Justice Pete he said no bump stops as the Bilsteins have them internal.
Matty Ice is offline   Reply With Quote
Old 06-21-2019, 10:01 AM   #3
SS 310H55A
Interesting. I called Bilstein to see what they say. The guy on the phone didn’t know for sure if it had internal bump stops. He pulled up the instructions on it and told me I should use the stock bump stops. The call did not inspire a ton of confidence.
Old 06-21-2019, 11:50 PM   #4
Zombie killer
Emerald Coast Camaros
Zombie killer's Avatar
Drives: 2013 2SS/RS L99
The fronts struts have internal bump stops. The rear shocks you reuse the factory bump stops. I am running lowering springs. However, I cut 1” of my factory bump stops. Since I believe the bump stops are linear in density , I took 1/2” off each end.
Zombie killer is offline   Reply With Quote
Old 06-23-2019, 08:51 PM   #5
Matty Ice
Matty Ice's Avatar
Here is some info
https://www.camaro5.com/forums/showthread.php?t=501911
Old 08-29-2024, 07:12 AM   #6
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
Old thread, but I'm curious if anyone here is running the B6's in the rear. What did you do about the bump stops? I see 3 different answers:
A. No bump stop at all.
B. Running the OEM bump stop.
C. Cutting 1/2in off the end of the bump stop.
These shocks/struts will be paired with a set of Hotchkis 1in drop springs.
Mods: GPI SS1 VVT cam, TSP long tube headers, LSA conversion, ZL1 fuel pump, ADM FPCM,
DW 700cc injectors, Lingenfelter solid isolator, Dedicated Motorsports ZL1 reinforced brick,
ADM Griptech 2.5 pulley, JLT CAI, Phastek intake scoop,NPP cat-back,
GM 3.91 gears, Eaton Truetrac, etc.
PhantomBlack is offline   Reply With Quote
Old 08-29-2024, 08:45 AM   #7
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Curious as well since I am running the same prings and plan to run the B6 as well.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 08-29-2024, 11:55 AM   #8
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
x3 curious as well. About to pull the trigger on some B6's in the next week or so. with 1.25" pfadt drop springs. I think I remember when installing the pfadt springs on the stock struts I cut half of the bump stock. But that was like 9 years ago so I don't remember exactly.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 09-01-2024, 09:28 PM   #9
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Please respond.
Bought these and hoping to install this week/weekend.
Old 09-02-2024, 06:36 AM   #10
PhantomBlack
Originally Posted by Jeff_SS View Post
Please respond.
If we don't get any responses please come back and let us know which route you took and how well it performs!
Old 09-13-2024, 06:24 PM   #11
Joe.G
Joe.G's Avatar
Any Updates?
Old 09-14-2024, 01:37 AM   #12
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Originally Posted by Joe.G View Post
Any Updates?
Installed driver rear. There was no bump stop that needed to be transferred from the factory strut.
Must only be on the fronts.
Going to do the passenger rear tomorrow.
EDIT: doing passenger side rear now.
It had a bump stop from the original strut. I had cut it when I installed lowering springs.
Odd that the driver rear didn’t have one but the passenger rear did. I must have forgotten years ago when I installed the springs.
I’m going to put this passenger side back together without the factory foam bump stop to match the driver rear I did a few days ago.
If it rides awful or makes a noise I’ll take it back apart and put bump stops in. Hoping I won’t have to.
Old 09-15-2024, 12:11 AM   #13
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Finished up installing both rear bilstein B6's. Didn't use GM factory bump stops. Feels great. Very smooth and firm in the right way when going over speed bumps or dips in the road - no suspension noise at all. AND my passenger rear end suspension rattle is completely gone. That strut was completely blown.
Highly recommend anyone contemplating the B6's to do it.
I will replace the fronts with bilsteins in the future.
Old 09-15-2024, 06:46 AM   #14
Joe.G
Joe.G's Avatar
Good to hear, I should have done them when I replaced every other suspension part.
