Old 06-18-2019, 11:25 PM   #1
dtek
dtek's Avatar
Drives: 2012 1lt
Oil leak maybe?
Was looking under the hood of my 2012 Camaro 1lt v6 with 97k miles and noticed some oil leakage on the circled part of the image I’ve provided, Part# 524. Took out one of the spark plugs and had oil on the threads and porcelain park of it. Any suggestions to what this could be? My car is kind of hesitant when accelerating and kind of jittery, and just last week I was driving in sport and either the car stalled or didn’t shift and felt like something yanked the car back out of nowhere. No mods done to the car besides installing a vittesse throttle controller and muffler delete. No check engine light but something feels wrong. Any answers will be great, as this is my every day driver.
2012 Camaro 1LT
Performance Mods:
• Cold Air Inductions CAI
• Overkill 80mm TB
• JacFab Extendolator
• JacFab LaminatorFX
• OverKill 93 Octane Tune
dtek is offline   Reply With Quote
Old 06-19-2019, 08:19 AM   #2
Marklar
Drives: 2012 Camaro LS V6
What do you mean by this? I thought 2012+ v6s didn't have a sport mode
Marklar is offline   Reply With Quote
Old 06-19-2019, 08:21 AM   #3
dtek
dtek's Avatar
Drives: 2012 1lt
Oil leak maybe?
It definitely does, slide shifter into Manual but don’t touch the paddle shifters and a “S” appears but as soon as you press a paddle, it switches to “M1-6”
I usually drive around in this mode because it jsut makes the car more fun to drive but ever since what happened last week I’m scared to drive the car in general without knowing if there’s a problem that I could potentially make worse
2012 Camaro 1LT
Performance Mods:
• Overkill 80mm TB
Old 06-20-2019, 12:51 AM   #4
mikeman
Banned
Drives: 2015 Camaro
I'd like to know what that is too. I believe it has something to do with the crankcase breather vent system.
mikeman is offline   Reply With Quote
Old 06-20-2019, 04:56 AM   #5
fhrex
Drives: 2011 Camaro 2LT/RS
it is indeed the PCV fresh air tube. you may be experiencing a vacuum leak at the tube, which could cause driveability issues.
fhrex is offline   Reply With Quote
Old 06-20-2019, 09:33 AM   #6
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
The LT models do. The LS models do not.
Anyway. On topic. I'd say you should either get a 1LE clean side separator (or Elite 1LE style) or hose clamp the end of that tube on the back of the motor, it's only under vacuum so at low vacuum it can come off or leak. I had a hose clamp on it but was never sure if that was enough.
Do you have a catch can?
DSX_Camaro is offline   Reply With Quote
Old 06-20-2019, 11:13 AM   #7
Marklar
I didn't realize both were available on the 2012s. I must have a LS because when I switch into Manual mode it automatically downshifts me and a number comes up on the HUD (not an S or M)
Old 06-20-2019, 11:18 AM   #8
dtek
dtek's Avatar
Drives: 2012 1lt
No I don’t
2012 Camaro 1LT
Performance Mods:
• Overkill 80mm TB
Old 06-20-2019, 06:17 PM   #9
DSX_Camaro
DSX_Camaro's Avatar
No I don’t
I would definitely invest in a catch can and a clean side separator. Well documented on the forum. And maybe an upper induction cleaning depending on your current mileage.
Old 06-20-2019, 06:59 PM   #10
dtek
dtek's Avatar
Drives: 2012 1lt
Oil leak maybe?
Bought it a couple months ago with 95k mikes I’ve put about 3k on it. The dealership said they did some 4 point inspection but I highly doubt it.
2012 Camaro 1LT
Performance Mods:
• Overkill 80mm TB
Old 06-20-2019, 07:15 PM   #11
DSX_Camaro
DSX_Camaro's Avatar
Cleaning the top end would definitely be worth it then. If you have a place that can walnut blast the valves that would be even better.
Old 06-20-2019, 07:33 PM   #12
dtek
dtek's Avatar
Drives: 2012 1lt
Will do but where is the oil actually coming from? And how did it get to the spark plug
2012 Camaro 1LT
Performance Mods:
• Overkill 80mm TB
Old 06-20-2019, 08:25 PM   #13
DSX_Camaro
DSX_Camaro's Avatar
Well currently you have 2 PCV lines that can vent oil to the intake, the one at the top of the topic that pulls from the intake and the one on the other side of the motor that pulls from the middle of the intake manifold (where a catch can would go). My can pulls a few ounces every oil change (at least 4oz, half a can) that would be in the intake tract.
Spark plugs, I'm not sure. Could be multiple things. Check all your cylinders and go from there?
Old 07-04-2019, 01:40 PM   #14
wardbg
wardbg's Avatar
Drives: 2014 Camaro 2LT Convertible
I had oil on the spark plug threads in a different type of car (Mazda 3, 2.3L I4). This was accompanied by a bad oil consumption problem. If you're driving it, I would check the oil daily. I ended up selling the car as-is, but I suspected leaking valve guides. I believe the oil has to be entering the combustion chamber close to the spark plug then the compression stroke forces it up through the threads. Maybe a long shot.
wardbg is offline   Reply With Quote
