Old 06-20-2019, 04:37 PM   #1
RalphGuevara
ZeusRS
RalphGuevara's Avatar
Drives: 2013 Camaro 2LT|RS
2013 RS 3 inch Exhaust conversion recommendations?
Hey forum, recently I've been interested in converting my 2.5 in exhaust from my 5th Gen but i am currently into running into issues for my research.
Right now im running Catless American Racing Headers which which happen to have a diameter of 2.5 inches, so i am for sure going to have to get a coupling for that but, i also have a Resonated X-pipe that has the same diameter of 2.5 inches as well.
I've been searching online and had no luck finding a Resonated x-pipe that is sold as 3 inches so will i have to cut those pipes off and weld on 3in pipes?
I feel like it would be pretty dumb to go from 2.5in to 3in back to 2.5in and then back again to 3in.
Also what do you guys recommend for the conversion? if you have a 3 inch set up can you share / link me the stuff you had purchased so i can have a wider range of options.
RalphGuevara is offline   Reply With Quote
Old 06-20-2019, 06:14 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Do you have boost?
If no, you'll lose power. Fluid laminar flow is super important, and exhaust gas is no exception. The V6 cannot cope with 3" dual exhaust properly. Why do you want a 3" exhaust? The cabin drone will be immense if you drive highway a lot.
Edit: If you have parts of the stock exhaust, they're actually 2.25". The ARH Catless downpipes are actually 2.5" and are nice (I have a pair) but from where the stock H pipe is back is all 2.25". Maybe start there?
DSX_Camaro is offline   Reply With Quote
Old 06-20-2019, 06:51 PM   #3
RalphGuevara
ZeusRS
Originally Posted by DSX_Camaro View Post
Do you have boost?
Well i was in a facebook group and there was this dude named Camaro ZLS who posted his exhaust videos and said he had a 3in Exhaust with the same Xpipe as well so that's one main reason why i was getting lost/confused.
Then in the comments there were other camaro owners saying that they went with 3in exhaust.
So i wanted to get like more opinions and thought posting here would be more informational
Old 06-20-2019, 07:13 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
He's running a supercharger on higher boost I believe.
I actually tried a 3" exhaust at one point and yeah it sounded cool but I went back to a 2.5" exhaust and it was significantly improved driving-wise. More power, better gas mileage, less drone. Maybe I feel it more because I'm on a manual, I know more than one person here has had an automatic and went with 3". I just wouldn't. An SS doesn't even have a significant power difference until like 700 or 800hp 2.5" vs 3". It's just more money. If you really want more volume get the MACE cams.
Like I said, start with a full 2.5" stainless exhaust and go from there, maybe add an axle back like Magnaflow, MRT, Corsa, Borla. There are plenty of options that are more than palatable. But a 300hp V6 cannot utilize a 3" dual exhaust properly. A single 3" exhaust pipe can support ~330hp.
Old 06-21-2019, 02:39 PM   #5
fnhowe84
fnhowe84's Avatar
Drives: 2018 Hotwheels M6 & 2010 1LE V6 M6
+1
CamaroLIFE
fnhowe84 is offline   Reply With Quote
Old 06-24-2019, 04:35 PM   #6
Marklar
Drives: 2012 Camaro LS V6
He has Overkill's Stage 3. Dude's getting 500+ hp. He needs the extra flow to push that much power. Unless you're pushing a ton more air than what the car is designed for (which would only come from high boost supercharge or twin turbos) then you'll lose power going up to 3" pipes. You won't be pushing enough air to keep the air flow laminar and it will cause backpressure.
Marklar is offline   Reply With Quote
3 inch, 3 inch exhaust, exhaust, v6 engine
