Old 06-21-2019, 11:20 AM   #1
rlg2014SS
rlg2014SS's Avatar
Drives: 2014 Camaro SS Red Hot
Launch control
Does anyone know if this works, or would a hurst roll control be better, need something to help hold her back on burn outs , lmk ??
rlg2014SS is offline   Reply With Quote
Old 06-21-2019, 11:58 AM   #2
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Well the 2 step is for setting your desired rpm for the launch itself, and the line lock holds your front brakes via a solenoid and leaves the rear brakes free so that its for one, easier to spin the rear wheels and do your burnout, but also saves your rear pads and rotors from unnecessary wear. Theres no reason you can't do both, as the 2 step goes off the clutch position sensor, and the Hurst line lock goes off your master cylinder. I see more guys using the Lingenfelter 2 step though.. happy launching!
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 06-21-2019, 12:13 PM   #3
rlg2014SS
rlg2014SS's Avatar
Cool thx man thx for the information, sure helps me a lot
Old 06-21-2019, 12:25 PM   #4
Chris49066SS
Drives: 2010 SS L99
No problem. I have the Hurst line lock with a couple pictures in my build thread (link is in my sig). It works very well, very effective
Old 06-21-2019, 02:33 PM   #5
rlg2014SS
rlg2014SS's Avatar
I was leaning towards the hurst I think first and see how it works, I heard it’s pretty good so thx again
Old 07-02-2019, 01:59 PM   #6
Nb1081
Drives: 10 2ss/rs
You can also use the line lock to hold car at the line so you can load the suspension and slip the clutch but if slipping clutch you will probably be to far out to activate the 2 step so you can also run a power or ground to activate it maybe t off line lock power with seperate toggle so you only use the 2 step at the light and not during the burn out
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
Nb1081 is offline   Reply With Quote
