Old 06-21-2019, 09:44 PM   #1
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
New PB, but still looking for that 11 sec ET
I went 12.073 @ 115.68 mph today. The DA was at 3,300 ft, IIRC.
Here is the slip. Sorry, no video.
I want to run an 11 so bad I can taste it. I keep going just a little bit faster every time we get decent air, so hoping it happens soon. In the summer we run in DAs above 4k feet regularly. Today wasn't too bad.
The track posted this picture on their FB page, so I got that going for me!!
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 06-22-2019, 01:10 AM   #2
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
Nice! I went to the strip for the first time ever today. My best mph was literally identical to yours, but I was 1.5 seconds slower doing it. I was having a hell of a time launching this car on street tires..it just hopped horribly bad, or occasionally broke them loose forever. I dont understand, I put have the suspension mods in my sig, it shouldn't wheel hop??
I know this car has 11s in it, so it hurt a little putting down a best if 13.09 for an et. If I got my 60ft down(and I know it needs a tire to do this), it likely has 117-118 in it through the traps.
To make things worse, I tried working on slipping the clutch to walk it out a little better. The pedal went flat off the line and the clutch fried on me :(
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 06-23-2019, 02:04 PM   #3
zlathim
zlathim's Avatar
I was running high 12s the first time I took my car to the track. Similar experience that you had, but I was spinning on drag radials. It just takes some practice is all. I have ovr 50 passes under my belt and I am feeling like I am starting to get the launch figured out for the most part.
The clutch situation you described sounds like many other I've read on here. I have an aftermarket slave and braided steel lines and I've never had an issue. Some guys swear by separating the brake and clutch reservoirs, but mine is still shared without issue.
Your rear suspension is set up fairly close to mine, but I'm not lowered. No idea if that adds to wheel hop or not.
Good luck getting everything squared away for next time.
Tuned by GPI
Old 06-23-2019, 02:48 PM   #4
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
You'll get it, Z. By November maybe sooner. When the weather turns, you'll get it
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 06-25-2019, 09:39 AM   #5
zlathim
zlathim's Avatar
Thanks, Chris. I think you are right about the better air in the fall.
Tuned by GPI
Old 06-26-2019, 08:24 AM   #6
abshire1006
abshire1006's Avatar
Drives: 2012 camaro ss
man your so close, that sucks, i was running low 12's then boom i had a good launch and my clutch was cool so i didnt miss a gear and ran a 11.8 on my street tires. you got this when the weather cools a little more
2012 SS, Magnuson supercharger, leathel racing night fury cam, ported throttle body, long tube headers,ACT twin disk clutch, BMR suspension, 620 RWHP 580 ftp 11.8 @121 1/4 mile time on 295/35/20 nitto nt555g2 tires
abshire1006 is offline   Reply With Quote
Old 06-26-2019, 08:39 AM   #7
zlathim
zlathim's Avatar
Thanks for the encouragement!!
Tuned by GPI
Old 08-22-2019, 06:41 PM   #8
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Zlathim, have you done any weight reduction to your car? I'm still kind of a newbie to dragracing (bracket racing) but I did a lot of research on what to do to help reduce weight without getting "to crazy" on our camaros.
remove all 4 floor mats
remove trunk floor mat and hard plastic cover and compressor
remove battery metal cover
remove glove compartment/console compartment stuff not needed
run out washer fluid
remove sun visors
remove headrests
remove windshield wipers (keep with you at the strip though in case it rains)
remove engine felt cover
remove plenum cover
remove front small black spoiler in front of car
Hope this helps!!!!!!!!!!!
Maroon 6.2L SS is offline   Reply With Quote
Old 08-22-2019, 07:28 PM   #9
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
remove sun visors
remove headrests
remove plenum cover
Nice!
Not sure on these cars but on 3rd Gens if you took that front spoiler off you'd have cooling issues all Summer long. Just mention it since might wanna keep an eye on that.
GL to you!
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 08-22-2019, 08:11 PM   #10
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
remove sun visors
remove headrests
remove plenum cover
I guess everything adds up the obvious thing would be the back seat.
StingrayblueSS is offline   Reply With Quote
Old 08-22-2019, 08:43 PM   #11
Chris49066SS
Drives: 2010 SS L99
remove sun visors
remove headrests
remove plenum cover
Good list. The rotational weight is going to make the biggest difference though, and lets you keep the creature comforts. Exhaust is heavy too.
Hey Z, any new track results lately?
Old 08-26-2019, 12:01 PM   #12
zlathim
zlathim's Avatar
No track news. I haven't been out much and when I have been out the DA has been pretty high. Like 5K-6k high. I'm looking forward to October for some good air.
I don't do much for weight reduction. I pull out the trunk floor and compressor and run with less than 1/2 tank of gas but that's about it. i'll probably do some of the other things on the list this fall if i have trouble getting into the 11s in good air.
Tuned by GPI
