Old 06-22-2019, 06:06 PM   #1
JTRATX
Drives: 17 SS 1LE, 14 Yukon Denali
Lightweight front crash bar with integrated tow hook
SOLD............
This is off my Z28, saved over 20lbs off the front of car. Weighs about 15 lbs. vs the OEM crash bar which is around 40lbs.
Would fit any 5th Gen.
Not sure if the tow hook would line up with a ZL1 or other Camaro model, but can be removed if not needed.
If for a Z28 it includes the tow hook cover that is trimmed perfectly to fit for a clean install.
Tow hook is from Rennline.
$250 shipped
JTRATX is offline   Reply With Quote
Old 06-23-2019, 12:15 AM   #2
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Is this a specific brand or did you make it? Do you know what the actual weight of it? What kind of metal is it?
Coz3z3 is offline   Reply With Quote
Old 06-23-2019, 08:56 AM   #3
JTRATX
It was made by Moreno Motorsports back when they made a run of them, from memory I believe it was made with chromo and I don't have a scale, I've been lifting since my teens and feels like a 15lb dumbell.
Old 06-23-2019, 10:09 AM   #4
Coz3z3
Ok cool thanks for the info
Old 06-23-2019, 11:38 AM   #5
Blown1LE
Blown1LE's Avatar
Drives: 2015 Supercharged Camaro 1LE
Sure looks like it would at least fit the 2014-15 ZL1 and 1LE as the lower grill is the same
Magnuson Supercharged 2015 1LE RS/2SS. Texas Speed Stage 3 Blower Cam. DSX Aux Pump. e85 Flex Fuel Kit. BMR Suspension. On Instagram @wakeyourneighbors @Blown1LE
Blown1LE is offline   Reply With Quote
Old 06-23-2019, 12:18 PM   #6
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Stock one weighs around 15 lbs, not 40 lbs.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 06-23-2019, 12:33 PM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
No, the stock one weighs in at 25.13 lbs and the aftermarket one comes in at 13.4 lbs ask me how I know.
Old 06-23-2019, 07:14 PM   #8
JTRATX
I was close on the aftermarket bar weight, but a bit off on the OEM bar, sure seemed heavier than 25lbs.
Old 06-30-2019, 05:44 PM   #9
JTRATX
I forgot to note installing this made a big difference in cooling. When you remove the factory crash bar and plastic crash bar cover it opens up a lot of space in front of the radiators.
Old 07-01-2019, 12:41 PM   #10
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
So you don't need the plastic crash reenforcement, so how does the it support the front end?
Orange Krush II
