Old 06-23-2019, 09:03 PM   #1
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
4 bogart eliminator with dr,s and slicks
looking to see what interest is local, not looking to ship.. these have been on car 3 times and run on track 2 times.. slicks are approx 6 yrs old but have been stored properly in dark air climate control area along with the 4 wheels.. front rims are 17x5.5 with 26x7.5x17 hoozier pro street tires..rear rims are 17x11 with mickey thompson 315/35/17 drag radials.. all rims are 5x4.75 which fit the camaro and also the vette.. they did not fit with the rollerskate calipers on front , but once removed they fit perfect..i had no issues with any type of rub but found the dr would not hook with my rwhp.. bought the slicks but never got around to mounting them and they been wrapped and sitting since 2013.. their is no dry rot..the hoosier slicks are 28x10x17.. 1 have 2 center caps and no lugs.. they disappeared while at the speed shop and we cannot locate them.. lets start at 1700..see what happens .. this is pick up price in port st lucie florida-34986
mikepage0007 is offline   Reply With Quote
Old 06-23-2019, 09:41 PM   #2
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Pm sent.
More to come.
Black_SS10 is offline   Reply With Quote
Old 06-23-2019, 10:55 PM   #3
Tommy434
Tommy434's Avatar
Drives: 2014 SS 2010 SS 93 Camaro z28
No shipping? Hmmm
Tommy434 is offline   Reply With Quote
Old 06-24-2019, 12:42 AM   #4
Js2fst
2010 transformer
Js2fst's Avatar
Drives: 2010 ss camaro
I wish I had time to go down. there we bought a convertible trans am there! Wish there was shipping
2010 transformer, vertical doors, 315nt05 rears, pedders supercar coilovers, hotchkis sway bars, links, adjustable, toe bars, bmr poly cradle bushings, 1le control arms, bmr tunnel brace, bmr subframe connectors. Cam 227/239-623-620@114 Mast medium bore heads, sw 1 7/8 headers, cat delete, x pipe, 3" dynomax true duals, fuel rails, fast 102 intake and NW 102 throttle body, catch can, rotofab cai, shifter, raptor custom shift light. Dss drive shaft, 3.91 gears. 492 rwhp
Js2fst is offline   Reply With Quote
Old 06-24-2019, 03:44 PM   #5
mikepage0007
Drives: 2010 camaro
sorry guys, at this time shipping 4 wheels and tires and slicks is a lot to ship..if i do not get local sale , thru cmaro5 -offerup-and craigslist, i may consider a pallet shipping if it is feasible..
Old 06-24-2019, 03:51 PM   #6
mikepage0007
Drives: 2010 camaro
this is what the eliminator lug nits look like.. i do n ot have the lug nuts and 2 missing caps
Old 06-24-2019, 05:12 PM   #7
mikepage0007
Drives: 2010 camaro
bogart d10. i thought they were eliminators but these were bolted 2 piece custom built wheels, not a 1 piece welded set, hence the bolts around the spokes..i checked some receipts and also spoke with steve at sjm who built the bogarts..these were custom built 17x5 and 17x10 d10 for a 2008 twin turbo vette by lethal performance and guy blew up car before putting wheels on car.. i got wheels and tires brand new as he had to pay up front and vette was totaled..link id the 1 piece wheel from bogart, not the 2 piece custom built wheel-cut and paste...http://coperformanceunlimited.com/p-...eels,+Set+of+4
Old 06-24-2019, 06:52 PM   #8
mikepage0007
Drives: 2010 camaro
more info so everyone is aware- no 17inch will bolt up to zl1 front brake system .. you can run a 17in on front with a 3mm spacer and 17x10 on rear with NO SPACER -there is no issue.. these will fit any camaro but with a little ingenuity.. cannot run rollerskate pads and have to be grind off.. will fit zl1 with 3mm spacer of front and no issue on back and this is not a issue for a 1/4mile run..hope that helps everyone-thanks
Old 06-28-2019, 09:32 PM   #9
Black_SS10
SomeguyK
Black_SS10's Avatar
Thanks Mike!
More to come.
