Old 06-26-2019, 03:36 PM   #1
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
2010 guys... Step inside.
Okay, have a question for you guys. For those of you that have 2010 Camaros, are any of you still running your original battery? The reason I ask is because I am still running mine and it runs perfect and I have not ever had any problems or hesitation. I guess I kind of look at it like, don't fix it or replace it unless it needs to be fixed or replaced. Do you think there's any reason I should? My car was built in September 2009. This thing seems to be perfect right now. Maybe it's because I have a tender on it 7 months out of the year.
newagemuscle is offline   Reply With Quote
Old 06-26-2019, 03:59 PM   #2
Ravenwood
Ravenwood's Avatar
Drives: 2010 2ss
Same battery. Stored the car for a few winters without a tender and just started it up every once in a while. Had it on a tender this year and it's still kicking. It's funny you posted this as I was just thinking the other day... Maybe I should change it?
Ravenwood is offline   Reply With Quote
Old 06-26-2019, 04:11 PM   #3
gtstorey
I think modern cars start doing weird things when the battery gets weak and could possibly damage something due to low voltage.
Old 06-26-2019, 04:14 PM   #4
Strydes
Strydes's Avatar
Drives: 2010 inferno orange 2SS 6spd
Changed mine out last year. Computer problems arise with old battery
roto fab cai
bbk full length headers
High flow cats
411rwhp/411trq
engine pulled/ oil pump fail
525 crate engine installed
391 gear installed
226/236 110 cam
tuned by full throttle speed
443@6000rpm /420trq@4900rpm
Strydes is offline   Reply With Quote
Old 06-26-2019, 04:26 PM   #5
rshelar
rshelar's Avatar
Drives: 2017 1SS auto vert Nightfall Gray
Every 4 years no matter what. Got stuck at an airport parking lot with a completely dead battery that would not take a jump. Had to be towed. Nightmare!
rshelar is offline   Reply With Quote
Old 06-26-2019, 04:55 PM   #6
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
I finally changed my original last winter when I went away for work for 2 weeks. I mean, I asked my fiancée to start it while I was away but she "forgot".
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 06-26-2019, 05:21 PM   #7
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
I had changed out my original battery in the 2010 LT2 auto when I swapped it for the SS this spring. I believe the SS battery is not original. I keep all my vehicles on battery tenders 365 days a year. My experience is they last quite a bit longer by using a tender.
0stones0 is offline   Reply With Quote
Old 06-26-2019, 05:22 PM   #8
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I have my original and its works fine, but its too heavy. I am getting a lightweight battery at my earliest convenience
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 06-26-2019, 05:23 PM   #9
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
i have my original battery...2010 with 5500 miles....voltage is perfect.
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 06-26-2019, 05:28 PM   #10
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
Still on original battery. CTEK maintainer used regularly.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 06-26-2019, 05:51 PM   #11
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
I changed mine out last year because it was starting to get a little sluggish after sitting for a few weeks at a time. I never had it on a battery tender either.
Check out my build thread
Old 06-26-2019, 05:56 PM   #12
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
Still on my original.....put it on a tender during low drive period in the winter...still works fine
EMB135Driver is offline   Reply With Quote
Old 06-26-2019, 06:08 PM   #13
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
My 2010 spends 6 months out of the year on a battery tender. After six years, I began to notice that the charging voltage when driving was always pegged at 15 volts. Whereas, with a healthy battery, the charging voltage is at just over 12 volts once in a while.
Even though the car was cranking normally, that was a warning sign. Then came the occasional Stabilitrac warning, indicating that built-in-test voltage was dropping low enough to cause spurious error codes.
Don't be the guy who is stranded by an old battery! No battery is going to be reliable after 9 or 10 years, no matter the maintenance. Even 7 years is a stretch. A new battery is short money for peace of mind.
Just do it!
Rock-It Man is offline   Reply With Quote
Old 06-26-2019, 07:51 PM   #14
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Still got my original battery here , never been on a tender and never been out of the car, plus we get cold winter's here -30 for months always stored outside as well. Thing is incredible for how long it has lived and still going strong
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
