![]() Drives: 2010 Camaro SS A6 Join Date: Oct 2018
Dyno tune options
When you get a Dyno tune, can they adjust shift points/firmness, idle rpm, rev limiter etc...
![]() ![]() ![]() ![]() ![]() Drives: 2010 SS L99 Join Date: Sep 2018
Yes, absolutely.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
Keeper of “THE list”
Absolutely! That's one of the greatest things about a dyno tune, or a tune in general. L99 cars are completely different animals after a quality tune. I asked them to tune a "wife mode" though. So "D" mode is more similar to stock with improved shift points and shifting, but "M" mode has firm neck snapping shifts that is great for getting rowdy.
#4 | |
![]() Drives: 2014 Chevy SS Join Date: Nov 2014
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4 2014 Chevy SS --- 429ci Hydraulic Roller LS3 |
#5 | |
#6 |
old school chevy rodder
They can also deal with torque management, fan engagement temp, etc...…...
#7 |
quick question: will a dyno tune be able to pick up on any issues that you may have qoing on "internally" with the engine? I've had some issues and people here have mentioned to pull the valve covers and inspect the rockers+rocker arms+springs.
#8 |
The tuner is going to be able to see any codes your computer is throwing. However, any issues would be something you would need to discuss with your shop ahead of time, way before they get it strapped onto the dyno. You'd want to tell them what you are hearing/feeling, then they scan for codes, and possibly do a test drive, and start troubleshooting during either one of these. The idea is that any problems are corrected before getting to the dyno and dialing everything in.
#9 | |
![]() Drives: Camaro Join Date: Oct 2018
