Old 06-27-2019, 12:07 AM   #1
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Code p0354
Anyone else had issues with this code before? I've already changed spark plugs with br7ef gapped at .024 and #4 coil. Second one up from the radiator on the passenger side. Code reads ignition coil d primary/ secondary circuit. What is the primary and secondary circuit? On the log when doing a pull, it drops my timing down to between 5 and 8°. My car is a 2010 ss with agp kit 62/62 turbos and a th400
camarosspower is offline   Reply With Quote
Old 06-27-2019, 05:22 AM   #2
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
Mine shows coil codes but they are permanent as listed in HP tuners. So I ignore them.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 06-27-2019, 07:52 AM   #3
camarosspower
This is what mine shows
Old 08-01-2025, 10:14 AM   #4
Caleb Mayo
Drives: Chevy CamaroSS Chevy CobaltSS
Did you figure this out? My 2013 SS single turbo setup has the same issue.
Caleb Mayo is offline   Reply With Quote
