![]() Drives: 2015 2SS Stock Join Date: Sep 2018
Finally got to a Dyno
I had the opportunity to Dyno my camaro over the weekend at Unlimited performance here in Corpus Christi. This was my baseline for my build while waiting for a couple $$ to come in. It out down 367whp and 350tq. I was hoping for a bit more but the owner said my car was about normal for the mods I have on that Dyno.
2015 2SS auto. AGP twin turbo, LS9 cam, BTR 660 springs, LS9 Gaskets, ARP studs, 400lph UPP fuel system, MBRP XP 3” cat back, 305/30 Micky Thompson Sport comp tires. 12” Fockford fosgate P1, Rockford Fosgate 600w amp.
USA-1
Torque should be higher than HP...at least that's how all the dyno sheets I've seen read.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS Victory Red 6M Join Date: Apr 2015
I see you're from CC. You should come up to Vtown sometime.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19 Gone on 12/28/19 R I P 2010 2SS 6M Victory Red/Black (old ride) CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back. 12.6 @ 115 SAR as of 9/19/15 Gone but never forgotten. |
![]() Drives: White 2013 SS/RS l99 Join Date: May 2016
Yea your hp is good but that torque seems low. Mine did 363 hp and 388 ft/lbs with a similar set up. Was it just a single pull?
Current: 2013 summit white Camaro 2SS l99 CAI, long tubes, ported tb, tune Previous: 2008 jet stream blue Corvette Z06 Airraid, Corsa, MGW shifter SOLD |
Started#gottalovethatblue
I agree with others. When I had similar mods I made 365rwhp/390rwtq.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 ZL1 - #670 Join Date: Jun 2009
I've noticed a trend, that the L99 makes better torque than the LS3. My SS for example with Intake, secondary cat delete and MRT cat back and LMS tune made 390/395 through A6 trans.
#7 |
Donkey Dick Cam Camaro
Drives: 2010 2SS/RS LS3 M6 Join Date: Oct 2009
No it doesnt
Bone Stock |
#8 | |
GPI Sales Consultant
I agree that the tq number looks pretty low for the original poster, especially in light of the hp. What type of dyno? How did the graph look? AFR recorded? Post it up!
Got a question about a GPI product? Feel free to shoot me a message! |
#9 |
Stigs Bahraini Cousin
424hp/422 lbft ls3 - cold day
418hp/422 lbft ls3 - hot day Airaid CAI, TSP 1 7/8 headers and X stock muffler.
2015 CAMARO 1LE
