Old 07-10-2019, 07:38 PM   #1
PumpinIron
Drives: 2013 Camaro 2SS
427 block with GPI Max Performance heads?
I recently ordered the GPI Max Performance package and MSD intake manifold.
In the near future I plan to do the bottom end. I'm well aware I can do a 416 block and keep the heads, but I'm curious as to whether I can do a 427 and retain my GPI Max Performance heads, or if that would require a different block and heads?
You'll have to forgive me since I'm new to Camaros (coming from BMW M cars) and LS engines in general.
Thanks!
PumpinIron is offline   Reply With Quote
Old 07-10-2019, 11:35 PM   #2
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
If you're talking about a stroked, 427ci LS3 or a LS7 engine (also 427ci) with ported GPI LS3 heads......no problem; they'll match.
On the other hand, the MSD intake will be for LS7 heads....LS3 heads will not work with that intake.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 07-11-2019, 12:03 AM   #3
PumpinIron
KW
Yes, I have the GPI Max Performance heads (modified LS7 heads as I understand it) on my LS3. I'm wanting to stroke the LS3 block and turn it into a 427ci. I just wasn't sure if that could be done to my existing LS3 block or not, since most of the guys seem to be running 416, and I wasn't sure why that is.
Old 07-11-2019, 02:28 AM   #4
weSS1LEy
weSS1LEy
weSS1LEy's Avatar
Drives: 2015 camaro 2ss/rs/1le
So the bore of an ls7 is different than an ls3 so I don’t understand how these heads could match both. Unless you have ls7 style heads that match the bore of an ls3 then you would stroke the ls3 to 427 but leave the bore as ls3. So you would end up with 427 but not ls7. Someone educate me on this please.
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
weSS1LEy is offline   Reply With Quote
Old 07-11-2019, 10:36 AM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
If you have already spent $$$ with GPI, why would you not ask them? I believe the GPI max head is for the LS3, LS7 block entirely different animal and different head pattern so not compatible.
Peeps run a 416 vs 427 stroke due to reduced piston rock a BDC.
good luck!
PEACE
Old 07-11-2019, 10:51 AM   #6
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Ls3 heads should fit a 427
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 07-11-2019, 11:57 AM   #7
Roader
Drives: Camaro
The other thing to look at is the aero force is a good IM but you’ll want to go to something different for a Mac effort 427 build. I saw a post, maybe an article, that it actually restricted compared to a high ram. Other than that I don’t know much about the aero force other than the 6th gen guys are getting really good results from it on sbe
Roader is offline   Reply With Quote
Old 07-11-2019, 11:44 PM   #8
PumpinIron
The AirForce Atomic manifold is supposed to make pretty good power, but I guess we'll see. I won't know for sure since I'm installing the complete GPI package all at once, including the intake manifold.
As for a high ram, does that require a bigger hood?
Old 07-12-2019, 12:27 AM   #9
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Hi ram needs cowl/ hood cutting. LOD is the intake you want to clear everything get the most of it.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 07-12-2019, 01:23 AM   #10
PumpinIron
Why is it that I can't find a price anywhere on the internet (or at least in my Google searches) for that LOD X1 manifold?
Old 07-12-2019, 06:21 AM   #11
Roader
Drives: Camaro
I’m not advocating for one over the other. just what was used on the application in the article. Just to be clear before a few people jump in here with their opinions
Old 07-12-2019, 07:00 AM   #12
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Www.lodspeedworks.com
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 07-12-2019, 07:48 AM   #13
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
The LS7 version is just around the corner. He will not find it yet........ Title of this thread is very misleading as well. You have an LS3 block and would be stroking it to 427 instead of 416. If you decided to purchase a LS7 block and build it you could then turn it 7800-8000. A stroker LS3 427 most are going to say 7200 to be safe.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 07-12-2019, 08:55 AM   #14
l.o.d_yankee
l.o.d_yankee's Avatar
Drives: 2010/2SS/M6/440ci
$1450+shipping and tax. The website is being revamped right now. I found it hard to find the price myself.
2010 2SS Camaro - Engine: 5.3 aluminum Re-sleeved 4.185 bore, 4 inch stroke, 12.5:1 compression, 440ci, SPS Dart pro1 ls3 heads, tsp ls7 stage 4.2 cam(too small), "billet bill" original X1 manifold, bbk 102mm, cai cold air. Exhaust: TSP 2 inch primaries, V-band merge, hooker blackheart x pipe (modified) spintech 9000 mufflers. Drivetrain: Dss 1 piece driveshaft, MGW shifter, Z28 clutch, ram aluminium flywheel. Body: ZTA spoiler, de-badged, ZL1 front bumper, 14-15 mohawk, two tone paint.
l.o.d_yankee is offline   Reply With Quote
