![]() Drives: 2014 procharged SS 1LE Join Date: Jun 2019
Works fine. Going a different route and dont need it. 3 days old with two extra gauge faces Reads all of the following RPM MPH Intake Air Temperature (post Intercooler) Ambient Air Temperature (pre Intercooler) Engine Coolant Temperature Exhaust Gas Temperature (PCM Calculated) Transmission Temp. (auto trans) Manifold Pressure (vacuum/boost) displayed in PSI Fuel Temperature Battery Voltage Battery Temp Injector Pulse Width in msec. Injector Duty Cycle (%) Air Flow Rate into engine Long Term Fuel Trim Short Term Fuel Trim O2 Sensor Voltage Barometric Pressure Ignition Advance Base Spark PCM Spark Adjust Fuel Status (open/closed loop) Wastegate Solenoid Duty Cycle (%) Knock Retard Knock Sensor Raw Voltage Throttle Position Percentage Throttle Position Sensor Raw Volts Calculated Net Horsepower Engine Load Transmission Slip Current Transmission Gear Torque Delivered to Transmission Torque Converter lockup status Brake pressure Brake Booster Travel Steering Angle Non-driven Wheel Speed Lateral G's Yaw Fuel economy (instantaneous and average) P-ratio - pressure ratio MAP/Barometer 2 user configurable analog inputs** |
LTCamaro
Drives: 2010 Camaro 1LT / 2014 C7 M7 3LT Join Date: Jun 2018
Asking price?
2010 Camaro 1LT
IG @LTCamaro Widebody, Built/Forged Engine, Cammed, Supercharged, Stalled,....etc |
S1N1STR
Price?
Sent from my iPhone using Tapatalk Pro |
![]() Drives: 11' ZL465 2RS/SS #3119 Join Date: Jul 2009
price?? and gauge led color? still have it??
"As I sit here in the lanes.. I know this round will take some brains heat the tires, Stage it slow. Amber drops Stick you bitch!! Time to go! Coming up on the stripe, It's going to be tight, Please dear God Turn on my Win Light!!!"
'11 ZL465 2RS/SS SLP#3119 of 4000 made. 1 OF 515 With a 6spd and Retro Pkg!Synergy Green. |
| Tags |
| boost, for sale, gauge, interceptor, pod |
