Old 07-16-2019, 10:06 AM   #1
Pyrodor
Drives: 2013 Chevy camaro 2ls
Serpentine belt
Someone in one of my camaro groups suggested a performance serpentine belt. What are the pro’s of getting one and is it worth it?
The part they suggested is:
Gates K060846HD serpentine belt green
Pyrodor is offline   Reply With Quote
Old 07-16-2019, 12:24 PM   #2
KillboyPowerhead
Drives: 2015 Z/22
Did they happen to suggest why to get said belt? The only thing an aftermarket belt would do over an OEM one is last longer/handle greater loads, so unless you're pushing the car real hard or racing it and/or you're super/turbo charged there should be no need to upgrade. Perhaps when it comes time to replace the belt you could get something like this, but I wouldn't go switching out the OEM just 'cause.
KillboyPowerhead is offline   Reply With Quote
Old 07-17-2019, 02:57 PM   #3
12blkgrayRS
12blkgrayRS's Avatar
Drives: 2012 Camaro RS 2LT 6spd man
+what he said, no performance gains here, the green will last way longer and is what the police dept vehicles use as well as the hoses. (severe duty).
12blkgrayRS is offline   Reply With Quote
Old 07-22-2019, 11:47 AM   #4
the85darkknight
Drives: 2015 Camaro 2SS Green Flash Edition
At what mileage is the serpentine replaced on 5th gens?
StarSaber Mk. II
IG: StarSaber85(https://www.instagram.com/starsaber85/)
Performance Mods:
CAI, Inc. Cold Air Intake; ADM Racing Scoop; Bo White Ported Throttle Body; GPI Ported Rod Mod Intake; Kooks 1-7/8" Headers with Catted Connections; Solo Mach XL Axle-Back Exhaust
the85darkknight is offline   Reply With Quote
Old 07-22-2019, 12:50 PM   #5
spyderbuddy
Been there, done that,wasted money, Bought the Green belt, said the belt had a 100,000 mile warranty, but so does the factory belt.
Old 07-22-2019, 04:10 PM   #6
12blkgrayRS
Check for cracking, when they start to crack, replace.
Old 07-25-2019, 02:12 AM   #7
SneakySS
OEM? Whats that?
Drives: 2014 Camaro SS Black Widow
I heard the green belts r stronger because theyre fleet belts.
2014 Southern Comfort Black Widow SS LS3
Magnuson Supercharger, ceramic coated ARH headers w/cat deletes, BTR blower cam, Mahle forged pistons, AEM Methanol injection, JRE 8 rib Super tensioner, Innovators West 8 rib serpentine pulley system, Melling high flow oil pump, Lingenfelter high flow fuel pump, McCleod RXT ceramic coated Twin disk clutch, Hooker BlackHeart exhaust. Escort 360 radar detector & dashcam.
Rockford Fosgate 1000w prime amp, 2X12” Rockford P3D2’s
Build and mods done by R&D Motorsports in Baton Rouge
Tune/Dyno done by ,,Engine Power Systems in Baton Rouge
SneakySS is offline   Reply With Quote
Old 07-29-2019, 11:55 AM   #8
12blkgrayRS
yes, they are more resistant to heat.
upgrade
