Old 07-17-2019, 02:31 PM   #1
firehead
firehead's Avatar
Drives: 2014 Camaro SS 1LE
Clutch upgrade?
Just wondering a couple of different things. One, I recently made quite a few mods to my Camaro and I should be pushing close to 500whp. I want to track her a bit (road course) but I do still driver her on the road too, what would be the best clutch to throw in her if my stock one decides to take a dump on me?
firehead is offline   Reply With Quote
Old 07-17-2019, 02:52 PM   #2
608RS
608RS's Avatar
Drives: 2015 2ss
you're going to get mixed answers but i'll toss in my .02 cents: i'm running a McLeod twin disk RST clutch and love it.
608RS is offline   Reply With Quote
Old 07-17-2019, 03:46 PM   #3
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
I am installing a D1x procharger and upgraded my clutch to a Monster LT1 Twin Disk clutch so I think it should hold what I am going to throw at it.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 07-17-2019, 03:59 PM   #4
RankSS
Drives: 2010 Camaro SS
Whatever you do make sure you put in a new slave with the billet bearing support.
I just had my trans in and out due to a failed slave. Only took 4 hrs start to finish though.
At 500rwhp the stock clutch will hold up pretty good. The stock slave may not.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 09-20-2019, 06:11 PM   #5
firehead
firehead's Avatar
Thanks guys, appreciate the feedback!
