Old 07-18-2019, 09:24 PM   #1
luisquirosr
Drives: Camaro RS 2013
Weird sound and brake pedal bounce on low speed Camaro LT 2013
Hi people, i am very new and i have this weird issue on my Camaro LT 2013, i have a sound like something metallic is loose on the front of the car and i have a vibration when i used the break, like my brake pedal bounce but only in low speed (Under 50 km/h), on this point all my ligths on the dash are Off, when i go faster than 50 km/h appear the message "Service Stabilitrak", and all my lights on the dash shows on (abs, traction control, check engine), like 3 or 4 differents ligths, on this point the vibration, the sounf of something is loose and the bounce on the brake pedal completely disapear and never shows again, until i turn off the car, when i turn on again the car shows the same exactly scenario on the same way always.
I hope the community can help me, because i go to three different mechanics and no one identify where the problem is.
Thank You All!
luisquirosr is offline   Reply With Quote
Old 07-19-2019, 10:34 AM   #2
LuSINda
LuSINda's Avatar
Drives: 2010 2SS/RS
Check your pads, rotors and hubs. The sensors are located in the hub and the noise could be worn pads.
Lusinda
2010 2SS/RS
LuSINda is offline   Reply With Quote
Old 07-19-2019, 10:47 AM   #3
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
a loose brake pad will cause this too. Need to inspect the pads/brakes/rotors to see what is going on. Could also be a bad sensor as mentioned.
Old 07-19-2019, 05:26 PM   #4
luisquirosr
Hi Thank You both, is not the Pads because I've already check and the mechanic tell me is a half of life, I think can be a sensor but I don't know what type of sensor can be :( Because the Service Stabillitrak message is related to a lot type of sensors not only one....
Enviado desde mi SM-C9000 mediante Tapatalk
Old 07-19-2019, 08:15 PM   #5
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
Could be warped rotors
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
