Old 07-19-2019, 11:25 AM   #1
irish108
Drives: chevrolet camaro
speed engineering header install
First of all, the headers are pretty decent quality for the money. However the passenger side is hitting the frame ever so slightly. Just enough to hear it nocking occasionally. The clamps did not completely seal the fake cat pipes. Had to get different clamps to finish it off.
So has any one else on here installed these and had the same problem? If so, what was your solution?
Thanks,
irish108 is offline   Reply With Quote
Old 07-19-2019, 11:47 AM   #2
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I did not have the hitting on the passenger side problem. Would probably just pull and dimple the header.
The clamps do suck but I knew that ahead of time from reading reviews, so I had different ones ready to go when the headers showed up.
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 07-19-2019, 12:02 PM   #3
xc_SS/RS
Drives: 2010 Camaro SS/RS
Mine touched the steering knuckle slightly on hard right turns. Took it off and dimpled it and no more noise.
Just put a small dimple/dent in the pipe. Not gonna hurt anything
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 07-19-2019, 12:35 PM   #4
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
To dimple them (which is common on a lot of headers), use a big socket like 35-36mm axle nut socket turned on its side and hit it with a hammer. It will cause zero loss in performance. Mark the header with a sharpie or a grease pen before you pull it off so you know where to clearance it.
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 07-19-2019, 12:59 PM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Mine touched on the passenger side frame, read many had this issue. Heated the header and dimpled it. I used stainless band clamps for the fake cats, I used a straight one but a stepped one would work better I think. They have them at most part stores now.
Greenhornet2 is offline   Reply With Quote
Old 07-19-2019, 01:30 PM   #6
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
Not sure what headers you're buying that is so common to need to dimple, but the ones I've installed haven't required dimpling. Unless you're talking about Speed Engineering specifically and then yes, many of their sets require dimpling.
Check out my build thread
Old 07-19-2019, 03:32 PM   #7
PepeLePew
PepeLePew's Avatar
Good point Pyro, I should have clarified. When I say common, it I mean it is something that happens with some percentage of headers... could be very low, but I've read accounts across the board on all of the Chinese manufactured headers that some need dimpling due to manufacturing tolerances. The American made Kooks, ARH, and Stainless Works headers are probably the only exceptions that I can think of where I have not read a case of dimpling needed especially in 1 7/8" X 3". I'm running the TSP 1 7/8" set and had no problem. But I've read that others were not so lucky.
Old 07-19-2019, 04:05 PM   #8
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
That's why I bought Kooks.
sscamaro is offline   Reply With Quote
Old 07-19-2019, 04:17 PM   #9
Juiced1
Drives: 2012 2SS CAMARO 45th
They are one of the only 1 7/8" header that needs to be dimpled. We see that more often on 2" headers but hard to beat them for the bang for your buck.
Juiced1 is offline   Reply With Quote
Old 07-19-2019, 04:18 PM   #10
pyroguy
pyroguy's Avatar
Drives: ABM #832
There's a reason why COPO Camaros have ARH and Cobra Jet Mustangs have Kooks and don't discount Stainless Works headers. However, not everyone wants to pony up the dough for a set from those manufacturers and I get that. However, like many things in life you get what you pay for.
Ditto. I love my kooks headers. I don't regret them for a minute.
Old 07-20-2019, 04:16 AM   #11
irish108
sounds like dimpling it is then. Thanks guys
Old 07-20-2019, 09:38 AM   #12
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
The speed long tubes I have fit perfect. Easiest headers Ive ever installed.
gunchamp is offline   Reply With Quote
Old 07-20-2019, 09:39 AM   #13
gunchamp
gunchamp's Avatar
And a friend of mine bought kooks and had a clearance issue. Can happen with any brand
Old 07-20-2019, 12:55 PM   #14
Greenhornet2
$300 vs $1500. I'll choose to dimple =)
