Old 07-21-2019, 02:03 PM   #1
Billie36
Billie36's Avatar
Drives: Chevy Camaro
Exclamation Anti Theft Alarm wont turn off
I have a 2011 v6, and A couple months ago my key fob unlock button broke. I was still able to unlock the car manually through the drivers door and the alarm would go off but after putting the key in the ignition the alarm would turn off and the car would start. Finally bought a new key fob online and had the same fcc id #’s as the original. I found a online tutorial on how to program the key to my car and worked great. A couple weeks later the key stopped working (my luck) and was back to unlocking it manually again. So i had the old key fob chip fixed and the buttons replaced (we soldered them back on). Went to try it on the car and the alarm went crazy for a few minutes so i unlocked the car manually and put the key in the ignition and the alarm stopped. Tried to turn the car on and it wont start. The anti theft yellow light is on and the alarm is still engaged. We’ve unplugged the battery multiple times in hope for it to reset, even had my battery tested to see if it was drained. We’ve re done the soldering on the chip to see if maybe we made a mistake and the cars key fob locks and unlocks the car fine now with no problems. But even though the car will unlock and the alarm will not sound the anti theft light is still on and my car will not start. We have asked nearly almost every car enthusiast in my area what to do and no one can answer it. Hoping someone on here can give me a answer since its my daily car and the only car i have.
Billie36 is offline   Reply With Quote
Old 07-21-2019, 05:50 PM   #2
LevonH
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White
https://repairpal.com/car-wont-start...d-chip-key-733
May help????
Levon H. Bone Stock
LevonH is offline   Reply With Quote
Old 07-23-2019, 11:16 AM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
You need to take the car to a Chevrolet dealer.
Rock-It Man is offline   Reply With Quote
alarm systems, anti theft, key fob, wiring, wont start
