Old 07-21-2019, 04:00 PM   #1
TheBumblebeeBoy
Drives: 2012 Camaro 2SS TF3 Edition
In need of advice...
So the unexpected happened about a week ago fellas. I started hearing a bad knock coming from the motor and a warning message that read "Low oil pressure - turn off engine". So I took it down to my local Chevrolet to get it diagnosed see what the problem was. The shop called me 2 hours later with some terrible news. He said my 6 year old ls3 with just over 60k miles on the odometer is done and that the bee needs a new motor. I'm still in disbelief about this happening since I don't give it a hard time on the road and only drive it every other weekend and maintenance is always done on time. What do you guys suggest? Not sure if I want to drop that much money to get a new motor put in it but at the same time I wouldn't want to get rid of it. Not sure what would be the best thing to do really?...
TheBumblebeeBoy is offline   Reply With Quote
Old 07-21-2019, 04:04 PM   #2
Welker2
Ret AF, cancer survivor
Welker2's Avatar
I would probably go with the new engine; a lot cheaper then replacing the vehicle
Old 07-21-2019, 04:53 PM   #3
theflea42
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro
I like to browse around for crate engines and stuff. I ran across a stock ls3, 430hp for $7362 here: https://www.jegs.com/i/Chevrolet-Per...70416/10002/-1. Summit racing has the same engine for the same price. Those are drop in, ready to run. You might get away with a long block, depending on what happened to your current engine.
That is a ton of money though. But, when comparing that to a new car, 7 grand isn't too bad.
theflea42 is offline   Reply With Quote
Old 07-21-2019, 05:41 PM   #4
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
I would be asking why this would have happened. Who does the oil changes? Hopefully they didn't short you on oil. I also might get a second opinion as it's a lot of money to sink into a car if it doesn't need to happen.
Check out my build thread
Old 07-21-2019, 06:05 PM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
You can ask your dealer if they will run a policy calculator for you. GM will take into considerationyour GM loyalty and such and come up with an amount they deem fair for you to pay. The dealer can also ask for a waiver of a share amount and do a DMA auth. I would be quite upset at 60k and GM may step up. If they wont run a calculator for you they dont like much, but you can can call CAC and discuss your issue and dissatisfaction. Other than that i would personally rebuild the engine stronger. May not be your thing, then a crate motor is more up your alley.
Greenhornet2 is offline   Reply With Quote
Old 07-21-2019, 06:12 PM   #6
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
Sounds like a perfect excuse to rebuild. Hell a rebuild can cost less then a new drop in crate. Take it to a real performance shop and have them diagnostic it. Just IMO, but dealerships suck. Chances are you don't need to throw away the whole motor to buy another. Lots of reusable pieces and parts and to add in the power parts... If it were me I would be taking it to a performance shop other than dealership. Have them tear down find the problem then the sky's the limit from there.
jcampos is offline   Reply With Quote
Old 07-21-2019, 06:25 PM   #7
TheBumblebeeBoy
Local Chevrolet has always done maintenance service on it. I'd hate to think they would half ass their work but than again who knows.
Old 07-21-2019, 06:29 PM   #8
TheBumblebeeBoy
My only concern is did I just happen to get unlucky with this one? Or what are the odds of this happening again 60k miles later on the new block I drop in it?
Old 07-21-2019, 06:30 PM   #9
TheBumblebeeBoy
Thanks for the info. I'll definitely be doing some browsing around.
Old 07-21-2019, 06:34 PM   #10
TheBumblebeeBoy
I tried speaking to GM about the issue already and all they able to tell me was " we're very sorry to hear this happened to your car but with your warranty being expired all repair costs are owner's expense."
Old 07-21-2019, 06:37 PM   #11
TheBumblebeeBoy
Rebuilding is starting to sound like the best option. I'll definitely be taking it somewhere to get a second opinion and see what's the best route to take.
Old 07-21-2019, 07:41 PM   #12
Roader
Drives: Camaro
I’d reach out to a reputable engine builder and see what they quote you.
Roader is offline   Reply With Quote
Old 07-21-2019, 11:17 PM   #13
captaincog
captaincog's Avatar
Drives: 1971 350RS/SS 4sp
I would move on. There are other things that will fail unless you are really attached to you ride.
Camaros currently owned: 1
2013 1LS 6speed.... Blue Ray Metallic now gone
and still have my first Camaro made 42 years before:
1971 RS/SS 350 4 speed Teal Green
captaincog is offline   Reply With Quote
Old 07-22-2019, 12:07 AM   #14
orange devil
You could always maybe call around at some local dismantlers. I have found some great deals on motors with low mileage.
orange devil is offline   Reply With Quote
