Old 07-21-2019, 07:55 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Which one would you do?
Hey all. I've got a 2010 A6 with most major bolt ons and most major suspension parts and drag radials. I'm thinking about one last upgrade (yah right). Just wanted to get a little opinion on what ya'll would do and the price difference vs bang for buck. Would you do a cam or gears?
Maroon 6.2L SS is offline   Reply With Quote
Old 07-21-2019, 08:05 PM   #2
Roader
Drives: Camaro
Do you have a TC and a budget? Cam and TC are going to be 5x the cost. If money not an issue I’m going with cam first
Roader is offline   Reply With Quote
Old 07-21-2019, 08:07 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Cam, converter and gears. You really need all of them to make it work, just need to decide which one first. I would do cam and converter together so if I was you I would do gears first. You need a converter with the cam unless its a small cam.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 07-22-2019, 08:00 AM   #4
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
I did SS1 cam and 3.91 gears at the same time, I'm enjoying it a lot.
Might do a converter next year just to see what the hype is about.
If you can only do one now most would say stall first, if it were me I'd do a cam first if it's small.
PhantomBlack is offline   Reply With Quote
Old 07-22-2019, 08:43 AM   #5
Redgt03
Redgt03's Avatar
Drives: 2011 Camaro SS
If you are not going to do a converter, then do gears from now. Then save up for the cam/converter swap.
2011 SS -GPI SS3 vvt, circle D 4c, 3.91 gears, solo mach xl exhaust, speed engineering headers, bo white ported throttle body, Roto fab intake, adm transcooler, elite catch can
Redgt03 is offline   Reply With Quote
Old 07-22-2019, 12:22 PM   #6
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
3.91 gears if not doing it all together
Then cam and a converter with appropriate spec to go with the cam.
I did them all at once. My mods are in my build thread if you care to see how I did it.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 07-22-2019, 01:39 PM   #7
PepeLePew
PepeLePew's Avatar
Drives: 2010 2SS Coupe; 2011 2LT Vert
bang for the buck huh?
I agree with Chris. About $1200-$1600 for gears.
Then Cam and Converter. Shop will charge $3500-$4500 for cam and AFM/DOD delete and tune depending on what supporting stuff you do at the same time tunions, oil pump, etc. Converter is another $2000 at a shop... so $5500-$6500 total.
I say if you are gonna put it in the shop to get some work done, go ahead and do it all at the same time to get the most out of it. With about 450whp and the other supporting mods, you can get this car in the low 11s maybe high 10s if conditions are perfect!!!
2010 2SS/RS LS3 - K&N, GM Performance Axle Back, Hurst Shifter, TSP 1 7/8ths long tubes no cats, TSP Stage 2 "Bald Eagle" cam, GM 3.91, 466whp/429tq
PepeLePew is offline   Reply With Quote
Old 07-22-2019, 02:52 PM   #8
Maroon 6.2L SS
Thanks everyone!!! I'm still learning. Didn't know that it was probably best to do a stall and cam together, and definitely didn't realize the price of each installed. Looks like the best bet will be to do the gears and start saving for a cam/stall in the future if I decide to go that route.
Old 07-22-2019, 03:37 PM   #9
Chris49066SS
Drives: 2010 SS L99
With the cam, its also best to do the C5R Katech timing chain, dogbone dampener, and the trunnion upgrade. Lifters and new baskets, the proper length pushrods, hollow stem LS3 valves, some good springs, etc. Advice is to just get with GPI and they can get you a kit that matches your goals. Not to mention the transmission cooler to keep the heat under control from that converter. And then the BR30 break in oil. And if you make it over to the West Coast, go to Wongs
^^^^^^^^^^^^^^^^^^^I got you covered, Christianchevelle, did I miss anything?
Old 07-22-2019, 04:57 PM   #10
Roader
Drives: Camaro
about 2 paragraphs
Old 07-22-2019, 05:02 PM   #11
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I see no mention of being an old school chevy rodder anywhere in your post though
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 07-22-2019, 05:03 PM   #12
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
LOL
. OBX LTH,Rotofab,Magnuson Heartbeat.AEM wideband, HP Tuners
hunter1660 is offline   Reply With Quote
Old 07-22-2019, 05:56 PM   #13
frey.199
Cam will be more expensive than gears, but I'd go cam.
Cam+ supporting mods that is
frey.199 is offline   Reply With Quote
Old 07-22-2019, 07:04 PM   #14
Maroon 6.2L SS
Great post Chris!!! We're like kids in a candy store with our cars. Kinda like girls needing 50 pairs of shoes for every occasion. I'm thinking just wear a black pair, that'll cover everything!!! They're like us. If I get to the point where I sell my fishing boat I will definitely go crazy with adding mods to the car.
