Old 12-09-2009, 10:15 PM   #1
76z28
76z28's Avatar
Drives: 1976 camaro
v6 forged internals?
Does the v6 have forged internals?
and how much power can it handle without upgrading them?
76z28 is offline   Reply With Quote
Old 12-09-2009, 10:19 PM   #2
fastal
Drives: 2010 2SS/RS, 2000 Z28
I've never heard anything about the LLT motor having forged internals so I doubt it but don't know for sure.
In the V6 section there has been some talk and it looks like the first bottleneck is the injectors maxing out in the mid 400's.
fastal is offline   Reply With Quote
Old 12-09-2009, 10:29 PM   #3
trudawg660
Drives: 2006 Dodge Charger / 2SS IOM
Features found on the 3.6-liter VVT DI include:
•Aluminum engine block and cylinder heads
•Dual overhead cams with four valves per cylinder and silent chain primary drive
•High-pressure, engine-driven fuel pump
•Advanced multi-outlet fuel injectors developed to withstand high pressure and heat
•Stainless steel, variable pressure fuel rail
•Four-cam phasing (VVT – see description below)
•11.3:1 compression ratio
•Aluminum pistons with floating wrist pins and oil squirters
•Polymer coated piston skirts
•Forged steel crankshaft
•Sinter-forged connecting rods
•Structural cast-aluminum oil pan with steel baffles
•Electronic throttle control with integrated cruise control
•Coil-on-plug ignition
trudawg660 is offline   Reply With Quote
Old 12-10-2009, 06:39 AM   #4
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
The pistons are hyperpathic... I mean hypereutectic... which means while they are strong and are very wear resistant, they are also very brittle...
Now I have not see the pistons in our 3.6 LLT but cars today tend to have rings are very close to the top, to reduce emissions, it makes the ring landing (the area of the piston about the rings), susceptible to cracking and breaking off during stress and loading, like boost or detonation...
So, my guess is the pistons are going to be one of the weaker links...
scrming is offline   Reply With Quote
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 387 09-19-2019 07:53 PM
GROUP BUY- Mach XL V6 (Manual) and Mach XLT V6 (Automatic)- Ends 11/30/09 GOINGSOLO2 V6 Bolt-Ons & Tunes 252 10-20-2011 09:33 PM
Forged internals Bungalowbandit Forced Induction - V8 6 12-07-2009 01:37 PM
forged internals Bungalowbandit Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 7 10-30-2009 10:11 PM
Cost for Forged Internals usmcjlp Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 07-07-2009 02:44 PM
