07-25-2019, 05:22 PM | #1 |
Debi
Carbon fiber rockers only -splitter would match rear bumper (not carbon fiber)
So I have been looking at Carbon Creations rockers. I just don’t know if it would look right being the only carbon fiber item on my car.
The rear bumper and the front would match themselves though. Thoughts on this set up? |
07-26-2019, 12:20 AM | #2 |
Drives: a Chevy Join Date: May 2016
Those side skirts remind me of the GFX side skirts. If you have the stock front and rear bumper with no aftermarket diffuser and front lip spoiler it might look tacky, but that's my $0.02. Also like you mentioned, being the only carbon fiber piece on the car would look a bit ricey. If your car is black you might be able to pull it off but anything else would be a no in my book
2011 Camaro 2LT/RS - BBK LT Headers w/ High-Flow Cats, MRT v1 Axle-Back, Cold Air Inductions CAI, SLP 1" Drop Springs, Vitesse Throttle Controller, Drake Billet Shifter, NPP rear diffuser, B.E.S.T. Stainless Steel Quad Exhaust, Clear Smoked Side Markers, Anvil Notch Spoiler, SS Front Bumper, Heritage Grille, SLP front splitter
07-26-2019, 05:57 AM | #3 |
Drives: 2015 Z/22 Join Date: Aug 2015
You could consider wrapping the front splitter/rear diffuser in carbon fibre wrap to make it look all the same. I painted all of my accents and whatnot (splitter, skirts, other aftermarket stuff) gloss black and I think it looks pretty good, although I still need to paint the rear diffuser (factory black matches fairly well as is, for now, but will get around to it eventually).
07-26-2019, 10:30 AM | #4 |
The rockers are one of those pieces that need to tie the car together, whether carbon fiber or a specific colour; it needs to correspond with something else on the car.
I am going for a similar set up, but I will have a carbon fiber diffuser and front splitter. Unless you can match it, aesthetically speaking, I don't recommend doing it otherwise.
GHOST · 2SSRS
Order Date: March 28, 2009 // DoB: June 19, 2009 // Arrival Date: July 2, 2009 Current Modifications:
07-26-2019, 10:41 AM | #5 |
Drives: Miss Con Ception Join Date: Aug 2016
You could paint the rockers body color.
I think it makes the car appear lower than black.
2011 1SS/RS LS3 CGM
07-26-2019, 11:18 AM | #6 |
Instagram: Sangstah
With those GFX style rockers you would need a low front lip to match IMO
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
09-03-2019, 09:01 PM | #7 |
Link to these? I’m looking for the basic black gfx side rockers but can’t find em anywhere..
Anyone else know? Also interested in seeing better pics of those cf ones Sent from my iPhone using Tapatalk
Cold Air Inductions CAI • Stainless Power LT's with HFC's • Flowmaster American Thunder Cat Back • APEX Scoop and WW Relocation Kit • VMAX Ported Throttle Body • Custom Dyno Tune • Pfadt 1.25" Lowering Springs • ZL1 Rims on 275 front 315 Rear • custome underlay vinyl wrap • Anvil Spoiler • heritage grill • APR Front Splitter • Custom Emblempros emblems • ZL1 Side Skirts • 416.5 whp 410 torque (CURRENTLY) Up Next: BTR Stage 3 Cam and supporting mods (in garage now)
