Old 07-26-2019, 06:51 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
3.27 to 3.91 gears in A6
Just curious. I have a 2010 A6 with most major bolt-ons and suspension stuff (trailing arms/toe rods and bushings) and stock 3.27 gears (no stall converter or cam though). Right now I'm running about 12.99 ET in 2100' DA with stock gears. If I upgrade to 3.91 gears this summer/fall, how much will my E.T drop? Next spring I plan on installing a Eaton True-Trac and Cradle Bushings.
Thanks
Maroon 6.2L SS is offline   Reply With Quote
Old 07-27-2019, 01:37 AM   #2
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Thanks
If you can maintain traction, the gears would easily put you in the 12.70 range.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 07-30-2019, 08:30 AM   #3
gnance2
Drives: 2013 Chevy Camaro 2SS
I went from 13.2 to 12.90 after adding 3.91 gears to my A6. I just have bolt ons. 60 ft was a tenth quicker.
gnance2 is offline   Reply With Quote
Old 07-31-2019, 08:06 AM   #4
frey.199
Drives: 2010 Camaro 2SS
Thanks
I was thinking the camaro did 13 flat, stock??? Only 0.01 with most major bolt ons? Hmmm, maybe I'm wrong.
frey.199 is offline   Reply With Quote
Old 07-31-2019, 09:57 AM   #5
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
There are a lot of factors to take into consideration like altitude, weather, driver, track conditions etc etc.
GJDM
LsxDoctor is offline   Reply With Quote
Old 07-31-2019, 02:05 PM   #6
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
Been years, but in best test conditions I think it was 13.2 or so
VR Baron is offline   Reply With Quote
Old 07-31-2019, 04:31 PM   #7
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Chevy advertised the 2010 with LS3 as 13.0@111.
The L99 was quicker 0-60, but ~0.3 slower in the 1/4. IIRC.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-01-2019, 08:43 AM   #8
JooktheSnooke
JooktheSnooke's Avatar
Drives: 2010 camaro ss
if you need some bmr diff bushings, I have an extra pair ive been meaning to sell. dm me if interested
2010 Cyber Gray Metallic 2SS/RS LS3 6 Speed -- Rotofab CAI | Stainless Works Longtubes w/ high flow cats | Muffler Delete | TSP 229/244 stage 2 cam| TSP .660" Spring Kit | TSP CNC Ported Heads | Mulling high volume oil pump | PTB | Trunnion upgrade | Hurst short throw shifter | Elite Engineering Catch Can | Exedy stage 1 clutch |
JooktheSnooke is offline   Reply With Quote
Old 08-01-2019, 08:30 PM   #9
ruby2010
Drives: 2010ss
I’d go converter before gears.
ruby2010 is offline   Reply With Quote
Old 08-01-2019, 10:14 PM   #10
2010reddevil
Drives: 2010 Camaro 2SS Victory Red 6M
Look at the mods in my sig. No gears needed for the A6. 1.6 60ft is all you need to know.
2011 2SS 6A Red Jewel Metallic, Vararam Tune CAI, Magnaflow 3" Competition c/b, Speed Engineering 1-7/8 LT's, Circle D 5C, M/T 275/40R20 S/S, HPTuners tune by Ryan@GPI
12.3 @ 112 ACM as of 12/22/19
Gone on 12/28/19 R I P
2010 2SS 6M Victory Red/Black (old ride)
CAI intake, Speed Engineering 1 7/8" LT's, X4 base tune, Flowmaster Outlaw axle-back.
12.6 @ 115 SAR as of 9/19/15
Gone but never forgotten.
2010reddevil is offline   Reply With Quote
Old 08-04-2019, 10:30 AM   #11
KW Baraka
KW Baraka's Avatar
Had one car....converter before gears, and a similar car with gears and no converter.
Overall drivability......went to gears w/no converter.
Yes....I do place value on the quality of the drive for the 10,000 miles per year that I drive OFF the track.
Jus' sayin'.
KW
Old 08-05-2019, 09:14 AM   #12
62nalide
62nalide's Avatar
Drives: 2013 SS
Converter before gears if you plan to track it. My L99 went 11.90s with headers, converter, OTR intake and drag pack full weight. This was back in 2013. Just depends what all you want to do and what direction you'd prefer to take. I waited until I did heads and a cam to swap gears went from 10.70s to 10.40s with a gear swap and seats out NA
62nalide is offline   Reply With Quote
