Old 07-30-2019, 07:19 PM   #1
Hilltop14
Drives: 2011 Inferno Orange 2LT V6 3.6L
Rough acceleration blinking CEL
Hey guys,
The other day I filled up my gas tank. About 20 miles down the road my fuel gauge went all the way to empty. After I got home I turned the engine off then back on and the gauge went back to Full. On Monday I noticed that the car was running a little funny. Noticeably at higher RPMS. It sounds like the engine is sucking air. So after work I got a new air filter and cleaned out the housing. I also put new gas in. Today after work I noticed it got worse. At the last stop sign I accelerated and at the high end of 2nd gear it sounded pretty ugly. Then the check engine light started blinking. I parked it and shut it off. I then turned it back on and the check engine light did not come on. I presume this is because the engine did not "misfire" since being started back up. Help. Please tell me I'm not screwed.
Hilltop14 is offline   Reply With Quote
Old 07-30-2019, 08:09 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
How many miles on the odometer? Any modifications done to the car?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 07-30-2019, 09:33 PM   #3
Hilltop14
No modifications and 106,000
Old 07-30-2019, 11:42 PM   #4
Dizzy82
Dizzy82's Avatar
Do you have a scanner to check the codes?
Old 07-31-2019, 12:39 AM   #5
hammdo
'It's an experiment'
hammdo's Avatar
Timing chains?
-Don
747 RWHP 794 RWTQ
Old 09-04-2019, 02:53 PM   #6
600hp-lpe
Drives: 2010
need to connect a scanner and check for codes. It'll tell you what is acting up.
600hp-lpe is offline   Reply With Quote
Old 09-04-2019, 04:42 PM   #7
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
This.
Let's shoot some guesses!
Im going with MAF
GJDM
LsxDoctor is offline   Reply With Quote
Old 09-13-2019, 04:03 PM   #8
JLGO
JLGO's Avatar
Drives: 2015 Camaro SS convertible L99
Check the fuel system, relays, pressure etc.....
JLGO is offline   Reply With Quote
Old 09-13-2019, 04:13 PM   #9
Vegas Bound
Drives: 2013 Sparkly Red One
2 cylinders fell off.
Vegas Bound is offline   Reply With Quote
Old 09-13-2019, 07:39 PM   #10
JLGO
JLGO's Avatar
Is that a joke. I hope you are joking, lol.
Old 09-17-2019, 08:33 AM   #11
ABM Camaro
ABM Camaro's Avatar
Drives: 2013 ZL1 A6 Camaro
Flashing CEL means the car is having misfires
Check your spark plug wires.
If you spray your air intake with oil and sprayed on to much, your MAF could have some oil on it.
2013 ZL1 Camaro A6. ARH Headers, K&N intake, Tuned by Tampa Tuning
2014
V6 Camaro bolt ons and E85
ABM Camaro is offline   Reply With Quote
Old 09-18-2019, 05:56 AM   #12
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Not enough information but I would start with battery and electrical connections. Electrical signals are sensitive so the connections should be clean and tight. Use electronic grease on connections.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
