Old 12-10-2009, 09:16 AM   #1
Ghost Rider
I'm one bad Mamma Jamma
Ghost Rider's Avatar
Drives: 2010 Camaro SS/RS
Question re: jumper cables
I've got a co-worker that needs me to give his car a jump start. I've got the cables and I know the battery is in the trunk. I also know there is a positive post in the engine compartment to hook the positive cable to. My question is, where do I hook the negative cable clamp? Do I just hook onto the fender or what? I haven't had to give anyone a jump in 15+ years.
I dare you to challenge my BRUTE!
http://ghost-rider-5.mybrute.com
DELIVERED on August 25, 2009- 2010 2SS/RS, Yellow, A6, VIN # 34902
DELIVERED on September 9, 2009 -Custom Bumblebee Stripes and engine cover.
DELIVERED on September 10, 2009 - Painted GFX
Ghost Rider is offline   Reply With Quote
Old 12-10-2009, 09:23 AM   #2
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
There is a little metal stud about as thick as a pencil. It will either be beside the positive post or beside the air box. Hook up the negative to that.
Old 12-10-2009, 09:27 AM   #3
Blade
Blade's Avatar
Drives: 2016 Camaro 2SS BVM
Yea I usually clamp the negative on a stud in the engine bay. Usually its right at the top where the shock are mounted to the car. I don't clamp the negative anywhere else, because I don't know better and I am scared of the rest of car getting fried
Blade is offline   Reply With Quote
Old 12-10-2009, 10:25 AM   #4
TooCool5
TooCool5's Avatar
Every time I jump it ruins my alternator diodes within 6 months after.
Old 12-10-2009, 10:28 AM   #5
Moriartii
Moriartii's Avatar
Drives: 11 IOM 2SS/RS M6 w/Hurst
Have the coworker find someone else to jump his car.
Cheers
Kinley
Moriartii is offline   Reply With Quote
Old 12-10-2009, 11:16 AM   #6
Rockin the BlueSS
The New Guy
Rockin the BlueSS's Avatar
Drives: 2010 2SS/RS IBM M6
How did you jump the car? Was your motor running or not running?
It is very important that when you jump a car you have your engine OFF.
if you connect your car to his and let the engine run a little (will add charge to his battery but slowly) then turn your car off, then have the other person start their car.
if your engine is running the alternator is making enough electricity to charge your bat and supply the elec. system if you try to start the other car the alternator has to try and charge your bat run the elec. system and start the other car spiking the diodes...
Rockin the BlueSS is offline   Reply With Quote
Old 12-10-2009, 11:18 AM   #7
I would not use the Camaro for jump starts, have your co worker ask someone else.
Old 12-10-2009, 11:23 AM   #8
esperman
You Can Call Me Jay
esperman's Avatar
Drives: 2010 1LT RJT Manual w/CAI & Solo
I recommend you carry a battery jumpstarter in your trunk.
esperman is offline   Reply With Quote
Old 12-10-2009, 11:58 AM   #9
Looney Tunes
Drives: 2010 Camaro 2LT ABM auto
Great info. Learn something new everyday.
Looney Tunes is offline   Reply With Quote
Old 12-10-2009, 01:55 PM   #10
jwjk
jwjk's Avatar
Drives: Ordered 2SS/RS - Nov. 14/09
As has been said, the problem is you're jumping the other car with your engine running. Your diodes are dying due to the high current draw from your alternator while cranking the dead car.
Jason
jwjk is offline   Reply With Quote
Old 12-10-2009, 02:18 PM   #11
jwjk
jwjk's Avatar
Hooking up the cables
I realize the following probably doesn't need to be said, but I'll say it anyway.
Hooking up jumper cables to jump start a dead car:
1) Connect a positive (+) end of the cable to the positive (+) of the dead battery.
2) Connect the other positive (+) end of the cable to the positive (+) of the good battery.
3) Connect a negative (-) end of the cable to the negative (-) of the good battery.
4) Connect the other negative (-) end of the cable to a clean, non-painted metal part of the engine with the dead battery.
To remove the jumper cables, remove them in the reverse order.
Also:
  • ALWAYS CHECK THE DEAD BATTERY to make sure it isn't cracked. If it is, STEP AWAAAY FROM THE VEHICLE. Try to jump start that battery and... ka-BOOM!
  • ALWAYS make sure you've unplugged everything... and this includes radar detectors. People always forget about the radar detectors.
Just doing my part to spare people some agony. The last thing you want is a battery exploding, or blowing up any cell phones/radar detectors you may have in your car.
Jason
Old 12-10-2009, 02:44 PM   #12
Blade
Blade's Avatar
^ This.
Question re: c.i. displacement and hp Arli 5th Gen Camaro SS LS LT General Discussions 6 03-24-2009 02:20 PM
Bored so Ill ask a speculation question :) BLACK SUNSHINE Camaro Price | Ordering | Tracking | Dealers Discussions 13 02-12-2009 12:16 PM
Ready to place my order this week - One Question BLACK SUNSHINE Camaro Price | Ordering | Tracking | Dealers Discussions 9 01-21-2009 10:20 PM
question about camaro affordability ChevyCowboy Canada 8 01-08-2009 07:02 AM
IRS question 454lsxss Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 5 08-30-2008 10:06 PM
