Old 07-31-2019, 11:06 AM   #1
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
Whipple Bypass actuator failure
While data logging I found that my LTFT's were +25. I couldn't find any obvious leaks so I did a smoke test and found that my bypass actuator had torn causing a large vacuum leak.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 07-31-2019, 12:20 PM   #2
TheBracketeer
TheBracketeer's Avatar
Drives: 2011 2SS Whipplecharged LS3
They do fail ... I had one go as well.
Luckily it is an easy and inexpensive fix.
I make a point of inspecting mine regularly now when I have the hood up and motor idling.
TheBracketeer is offline   Reply With Quote
Old 07-31-2019, 12:29 PM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
The new ones are made from a better material we carry them in stock most of the time.
give us a call if we can help you out. 203-753-7223
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 07-31-2019, 01:15 PM   #4
BigMatt
BigMatt's Avatar
Ted.
Thanks Ted. I ordered one direct from Whipple yesterday after I found the tear. What new materials are they made out of?
Old 07-31-2019, 01:20 PM   #5
JANNETTYRACING
Nitryl I believe red in color
Old 07-31-2019, 04:11 PM   #6
BigMatt
BigMatt's Avatar
Hopefully the new one will be more stout. I was surprised how cheaply this one seems made.
Old 08-02-2019, 07:39 AM   #7
Axe55
Drives: 2012 Camaro SS
I had a similar failure on my bypass actuator, it happened within the first couple of months after install. I contacted Whipple and they sent me one under warranty, maybe they know it's a bit of weak point?
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Old 08-03-2019, 04:20 PM   #8
Kman13RSSS
Drives: 2013 IOM 2SS/RS 2.9 Whipple
Other then seeing it on the data logger could you tell something was different?
Kman13RSSS is offline   Reply With Quote
Old 08-04-2019, 04:33 PM   #9
BigMatt
BigMatt's Avatar
My afr at idle and cruise was 16-17. It started and drove fine though.
Old 08-05-2019, 04:45 PM   #10
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
Dang! Now I'm gonna go check mine when I get home.
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo
Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading...
Aries240SS is offline   Reply With Quote
Old 08-05-2019, 08:12 PM   #11
Kman13RSSS
Thank you. Did you have a boost gauge? I’m thinking you wouldn’t see any boost building if that wasn’t closing.
Old 08-08-2019, 11:03 AM   #12
BigMatt
BigMatt's Avatar
It was stuck in the boost mode. So iats were very high, but no boost loss
