Old 07-31-2019, 07:24 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
3.73 vs 3.91 gear install cost?
Is it more expensive to install 3.73 gears vs 3.91 gears on an Auto? Reason I'm asking is because I see you can by the GM Performance 1LE "Gear Kit" for a descent price vs just gears
Maroon 6.2L SS is offline   Reply With Quote
Old 08-01-2019, 08:38 AM   #2
JooktheSnooke
JooktheSnooke's Avatar
Drives: 2010 camaro ss
installing gears should be the same price regardless of what size they are. gear ratios is just the numbers of teeth on the ring and pinion so that doesn't effect the install process. I just put 4.10 gears in my car. did all the work myself so that saved money
2010 Cyber Gray Metallic 2SS/RS LS3 6 Speed -- Rotofab CAI | Stainless Works Longtubes w/ high flow cats | Muffler Delete | TSP 229/244 stage 2 cam| TSP .660" Spring Kit | TSP CNC Ported Heads | Mulling high volume oil pump | PTB | Trunnion upgrade | Hurst short throw shifter | Elite Engineering Catch Can | Exedy stage 1 clutch |
JooktheSnooke is offline   Reply With Quote
Old 08-01-2019, 09:36 AM   #3
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
The GM kit will come with a certificate to calibrate the speedometer at a GM dealer. Might save you a few bucks that way.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
