08-01-2019, 03:47 PM | #1 |
YOLO Z/28
Drives: 2014 Z/28 Join Date: May 2016
F1A or F1A-94?
Any one on here with real world experience. Looking to upgrade my P1-X. Wondering if the older F1A design, which makes more power/torque under curve will be better for out heavier cars.
In theory, I feel the -94 makes sense for lighter cars like vettes, but a standard F1A would be better for our 4000lbs cars
2014 Red Hot Z/28, CTF car #39/69. HCI, Supercharged, boltons.
2006 SRM GTO, exhaust, VMR V701 wheels (SOLD) 2002 Bright Red Trans Am WS6: HCI, exhaust, tune, Konis, UMI sways, LCAs, Track bar, STB, 2" boxed steel SFCs (SOLD) |
08-01-2019, 07:28 PM | #2 |
Drives: 2012 2SS/RS LS3 Join Date: Dec 2011
I run a f1a with a 3.85 12 rib, it's not quite enough for my setup. Going to be dropping down to a 3.55 to bring it in earlier before eventually going F1x
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
08-01-2019, 09:00 PM | #3 |
YOLO Z/28
What kind of boost are you seeing on your application? I know the F1-X is the Mack daddy, but I'm not willing to sacrifice my strut tower to get it to fit. My P1-X is definitely mismatched and out of steam on my application. It makes 8psi with a 3.7 pulley on a 7.0L. I wanted to initially hit the numbers I have, but eventually grow to 16psi.
08-02-2019, 11:12 AM | #4 |
I am making around 16lbs now on my low compression 7.0L with the size pulley I have right now though I am not picking up real steam until about 3500 rpm. I am wanting to get the F1X and you can massage your strut tower with a hammer I hear...... or have it cut and boxed professionally.
08-02-2019, 04:55 PM | #5 | |
YOLO Z/28
You can make it fit for sure. I've seen SS's with pro notched strut tower braces. I just dont want to go back sawing on my Z/28 that I like to throw around turns on the occasion. Thanks for your input!
