Old 08-01-2019, 03:53 PM   #1
hazy
Drives: 2011 2SS/RS
changing radiator fans out this evening...any tips?
appears to be a pretty straightforward swap, 2 bolts, a connector, and then pull it out....any tips/tricks I should be aware of?
hazy is offline   Reply With Quote
Old 08-01-2019, 11:12 PM   #2
hazy
Drives: 2011 2SS/RS
Well for anyone else who may have to do this...its real straightforward. A pain to wriggle it out with the intercooler piping, but a straight up in/out done in an hr and a half hood up to down, cold beverage included along the way.
Old 08-02-2019, 10:28 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
That's the way it all should be!
Old 08-03-2019, 09:24 AM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Any upgrades over factory fan?
Orange Krush II
Old 08-05-2019, 02:54 PM   #5
hazy
Drives: 2011 2SS/RS
I looked around for upgraded fans, but I really couldn't find anything that seemed totally guaranteed to fit onto a stock radiator. I was in a pinch bc my setup was running SUPER hot - turns out one fan was inoperable. My shop said that they typically don't see any cooling issues with the stock radiator setup, so I went ahead and pulled the trigger on THIS set of fans. Managed to get it for 260 shipped overnight with the 20% off coupon they were running.
Busted a few knuckles on the install, but overall it was a pretty painless in/out. Temps with my current setup (built 416 w all the bolt-ons, f1a procharger, Fore level 2, DSX flex fuel sensor) haven't seen over 214* since install - that was sitting in heavy traffic at 95* outside temps with the AC blasting cool air. I don't do much any driving that is too strenuous on the cooling system outside of the typical daily city driving, so didn't really feel the desire to spend the coin on a serious upgrade to cooling if the factory system would handle it
if I were building a purpose-built track car, or autox car, then the situation might be different, as I believe they see pretty high temps when they're in the thick of it, but with my situation it's not really warranted.
