Old 08-01-2019, 07:16 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Tire pressure on Nitto drag radials
So I'm gonna start doing some bracket drag racing on the weekends with my 2010 A6. Not much driving other than that, it's a bucket list thing with the car this year (maybe next). I have most major bolts ons including suspension (no cam or stall though and stock gears). My thought process is I should be able to run the drag radials at a higher PSI (maybe 24-26) than say the normal 18-20psi because I'm only putting down 450-460 at the motor (not the wheels). Is this correct thinking or are the Drag Radials set up to run at a certain PSI regardless if your putting down 450hp or 800hp?
Maroon 6.2L SS is offline   Reply With Quote
Old 08-02-2019, 09:33 PM   #2
ruby2010
Drives: 2010ss
I always run between 24-27psi on my H/C stalled 98. I’ve nvr not hooked with uncle mickeys.
ruby2010 is offline   Reply With Quote
Old 08-03-2019, 09:44 AM   #3
Vegas Bound
Drives: 2013 Sparkly Red One
Air pressure is case by case. Start at 25. Adjust accordingly if you spin or hook. Repeat.
I run 17.5 for most track situations.
Vegas Bound is offline   Reply With Quote
Old 08-03-2019, 05:47 PM   #4
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
I usually start out at 22 and work my way down. For my ride 18-20 is the sweet spot depending on the day.
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.73 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
