Old 08-05-2019, 12:14 AM   #1
richard200593
richard200593's Avatar
Drives: 2012 45th Anniversary RS
What wires to tap into for front camera
I am installing a front facing camera on my Camaro, and instructions are designed for rear facing and to tap positive wire into reverse lights, but since I am running it as a front camera obviously that’s not an option. It still had a yellow video wire running to my head unit but I’m guessing it’s not a remote on and off. Would it be ok to run it to any accessory hot wire and hopefully be able to toggle the video off from the head unit or is there a better option?
*Performance:
mrt v2.0 exhaust/CAI Intake
*Cosmetic:
Zl1 factory Reproduction wheels
Bmr 1.2/1.4 springs/Oracle plasma drl lights, footwell ambient lighting, 45th Gobo lights
*Audio:
Memphis pr600 amp/Fosgate 12" t0 sub/******** stealth box
richard200593 is offline   Reply With Quote
Old 08-20-2019, 07:16 PM   #2
kmarshall2121
kmarshall2121's Avatar
Drives: 2012 45th Anniversary Edition
the 'cig' lighter ' charger wire turns off when the car is off. Do you want a constant hot so it works when the car is off? So you can see when / if something happens in your absence?
kmarshall2121 is offline   Reply With Quote
Old 08-22-2019, 06:31 PM   #3
cfosceola
cfosceola's Avatar
Drives: 2017 Camaro ZL1
Just tap into the red or blue wire on the head unit.
cfosceola is offline   Reply With Quote
Old 09-06-2019, 09:29 PM   #4
1Coopgt
1Coopgt's Avatar
Drives: All Black 2012 1LS
Can anyone say where they ran the Vid cable through the firewall?
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
1Coopgt is offline   Reply With Quote
Old 09-26-2019, 09:54 PM   #5
Mattchew
Mattchew's Avatar
Drives: Camaro 2011 RS
+1
Sometimes Rattlecan rims look good...
Mattchew is offline   Reply With Quote
Old 09-27-2019, 03:24 PM   #6
Fonse
Fonse's Avatar
Drives: Camaro 2SS/RS M6 45th Edition 2012
[QUOTE:Can anyone say where they ran the Vid cable through the firewall?
In the engine bay, remove the cabin air filter and frame. Then you see 2 holes with rubber plugs in. Push or pull the plug out. I used a fish tape to pull the video cam wire thru. I tried it with a stiff wire before but there is too much insulation under the passenger dash and i didn't wanna take more stuff apart as needed.
2012 2SS/RS 45th Edition
Fonse is offline   Reply With Quote
