Old 08-06-2019, 01:13 PM   #1
sheplex02
Drives: 4 wheels, engine, trans, and seats
Diff additive
So I just did a drain and fill on the diff and used a pump to get the entire bottle of Redline 75w90 in. Went to add the additive and had to add the entire 4oz bottle to get fluid to the fill point. Is there any issue with having the entire 4oz instead of 2.5oz in the diff housing?
sheplex02 is offline   Reply With Quote
Old 08-06-2019, 01:28 PM   #2
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
Nothing wrong with adding all 4oz.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 08-06-2019, 01:31 PM   #3
sheplex02
coolio.. was not feeling or hearing anything bad, but I figured I would ask.
Old 08-07-2019, 02:28 PM   #4
Russell James
Russell James's Avatar
Do about 10 slow figure 8s in a parking lot. It helps get that additive into the clutch surfaces. That amount is fine, many put a little extra in to make it last a bit longer. The additive wears out quick if used hard.
Old 09-05-2019, 02:16 AM   #5
rdanzel
Drives: 2010
I like the Valvoline Synthetic that has limited slip additive already for ease of use.
rdanzel is offline   Reply With Quote
Old 09-05-2019, 01:07 PM   #6
LevonH
Chevy Enthusiast.
Drives: 2015 Camaro ZL1 Summit White
I read that the Redline has the additive as well???
https://www.redlineoil.com/75w90-gl-5-gear-oil
Levon H. Bone Stock
LevonH is offline   Reply With Quote
