Old 08-07-2019, 09:21 PM   #1
Shookemup
Coyote Killer
Shookemup's Avatar
Drives: 2011 Camaro 2SS
Brakes
I just upgraded my front brakes with an eight piston big brake kit, can I use my old front calipers on the rear?
Magnuson TVS2300_8PSI, ZL1 Fuel Pump, Ride Tech HQcoilovers-lvl 2, BMR Sway Bars,1LE toe links, LSR end links, Pedder's cradle bushings, UMI trailing arms w/Roto Joints, Z/28 radius arms, Z/28 rear upper control arms, SLP front splitter, ZL1 Rear spoiler w/ wicker bill, 373 gears
Shookemup is offline   Reply With Quote
Old 08-07-2019, 09:50 PM   #2
bdd8401
Drives: 2015 2LT SW RS A6
Never heard of anyone else doing it, but if the caliper will bolt to the rear spindle and the front rotors would fit the back it might work. You will probably lose the rear backing plate or dust cover or whatever it is called. Guess you will have to try and see if all the parts will fit the rear of the car.
bdd8401 is offline   Reply With Quote
Old 08-07-2019, 10:11 PM   #3
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
The rear brakes have drum brakes inside the rotors for the parking brake.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 08-08-2019, 12:08 AM   #4
bdd8401
Okay so are the front and rear rotors the same size on the ss then, otherwise doesn’t sound like he can do it if rotors are not the same size.
Old 08-08-2019, 06:46 AM   #5
Dogmeat
Dogmeat's Avatar
Drives: 2011 RS
He's not talking bout changing the ROTORS, only the calipers, and the fact that the parking brake is inside the rotor, has no effect on the calipers.
Proud Owner Of '11 Camaro
Dogmeat is offline   Reply With Quote
Old 08-08-2019, 09:49 AM   #6
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
On the SS, the pad size and rotor size are different on front/back. The back rotors and pads are slightly larger. I think it could work. I've done plenty of brake work on my car.[/URL] I've completely removed the rear calipers temporarily when I painted them. The rear calipers are not connected to the parking brake.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 08-08-2019, 09:52 AM   #7
wasthatacop?
Drives: 2010 2SS
THis wouldn't effect changing calipers and/or rotors. But why would you want to put the smaller 'front' hardware on the 'rear'? Currently the rear brake hardware is larger in size.
ZL1 factory rims
Old 08-08-2019, 12:56 PM   #8
Shookemup
Coyote Killer
Shookemup's Avatar
Pretty sure the front calipers are larger if not more pistons... thats why I would swap them.
Old 08-08-2019, 01:50 PM   #9
CamaroFred
CamaroFred's Avatar
2011 1SS/RS LS3 CGM
Old 08-08-2019, 05:06 PM   #10
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
I'm sure the front and rear rotors are different sizes. They are on my V6, so i'm sure they are on a 2SS. Unless, you're trying to use your old front brakes to upgrade your rear brakes, but not sure the brackets will match up. Let us know.
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
Old 08-10-2019, 07:32 AM   #11
Hephaestus1
Hephaestus1's Avatar
Drives: 2010 2LT/RS A6
SS Front brake rotors = 13.976" dia, 1.259" thick (new). Rear rotors = 14.37" dia, 1.102" thick (new). These are 2010 numbers, but they should be the same for 2011.
V6 Front brake rotors = 12.64" dia, 1.181" thick (new). Rear rotors = 12.40" dia, 0.906" thick (new).
Guess the V8 needs more parking brake "space" than the V6.
Hephaestus1 is offline   Reply With Quote
Old 08-10-2019, 07:53 AM   #12
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
No you can't put the front 4 pot brembos on the rear. Not without some modifications. Also, whats the point? You don't need such large brakes in the rear.
More to come.
Black_SS10 is offline   Reply With Quote
