Old 08-07-2019, 10:44 PM   #1
InTheMarket
InTheMarket's Avatar
Drives: 2013 Camaro 2SS
Headers and Straight Pipe, Homeowners Association... Help!
My Car: 2013 Camaro 2SS LS3 Manual, headers no cats, muffler delete.
So I bought a Condo and I can already tell based on the neighborhood and my neighbors that my hulking headers, no cats, no muffler LS3 could possibly wake the neighbors as I leave for work every morning. I'm trying to head off the issues, with some axle back solutions that will quiet down the exhaust noise a bit. Does anyone have experience with this issue, I searched the forums but could not find my specific situation. Am I worrying for no reason?
TL;DR: Headers, no cats, muffler delete, but looking to add a muffler to quiet it down.
2013 Camaro 2SS: Summit White-Mojave Leather Interior : K&N CAI : Pypes Bomb Axle-Back Exhaust
InTheMarket is offline   Reply With Quote
Old 08-08-2019, 12:20 AM   #2
InFiD3ViL
InFiD3ViL's Avatar
Rather expensive, but Varex makes a muffler and cat-back system with built in valving and key fobs/gps/app control that has 100% controllability.
This guy installed it on his 5.0 and it sounds really good. Not sure how it sounds on LS though The GPS control is an awesome feature for someone like you. No worrying about even having to mess with it. it is automatic based on what you set for location.
But obviously, that's probably the most expensive option.
Old 08-08-2019, 07:11 AM   #3
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
I leave for work at 6 am so I just fire up the car inside the garage with the door down and then open it up after 30 seconds or so when it settles down. Not sure how much it really helps cut down the noise but I've been doing it for 2 years and the HOA Nazis across the street haven't made any complaints yet. I'm guessing you have to park outside though so I would recommend a really quiet cat back and a set of cut-outs.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 08-08-2019, 07:41 AM   #4
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
I do this also. My neighbors are pretty cool and love my car, but I don't have to be a dick early in the morning either. I respect their sleep too. So I keep the garage door closed till it idles down and slowly pull out and down the street. Once on the main highway... then release the fury and the smile.
Old 08-08-2019, 07:59 AM   #5
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I leave at 7AM. I haven't had anyone complaint yet. I just don't get on the throttle in the morning at all, too early anyway I'm half asleep lol. I too am curious if anyone knows a muffle that will quiet down the beast with headers and no cats. I love how the car sounds but it is a little much, can hear the thing from over a mile away when that boost kicks in.
Greenhornet2 is offline   Reply With Quote
Old 08-08-2019, 09:24 AM   #6
SlingShot
SlingShot's Avatar
Drives: 2012 ZL1 - #670
You can always put the LS3 cans back on. They will make it quieter, until you put your foot in it then they get loud and sound very good.
Old 08-08-2019, 09:44 AM   #7
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
HOAs can be a pain in the butt. I live in a house, on a cul-de-sac, with an HOA. I have a muffler delete and work in construction... so I leave at 5am. Surprisingly no one has complained yet. But HOAs do have a tremendous amount of power and you need to be careful.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 08-08-2019, 09:45 AM   #8
SSkat
SSkat's Avatar
Drives: 2010 Camaro 2SS
Borla S-type axle back will quiet it down a good bit. I just switched over to an Atak from the S-type because it was too tame for me. I live in a condo as well and with the atak the cold star is pretty harsh sometimes but no complaints from neighbors yet.
SSkat is offline   Reply With Quote
Old 08-08-2019, 10:17 AM   #9
xc_SS/RS
Drives: 2010 Camaro SS/RS
Look at some Magnaflow mufflers. Sad to say it there isn't really a solid solution for loud cars and HOAs lol I feel your pain though. The magnaflows will at least retain the volume when you're WOT and get louder with age. The resonated x pipe is a great solution that will cut enough volume to keep them happy
I thought a NPP system would be good but it does squat even with the valves closed. So I'm going back to a Magnaflow exhaust
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 08-08-2019, 10:38 AM   #10
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Maybe some kind of mild 2 wild switch system where you can quiet it down until you leave the neighborhood?
SSEssence is offline   Reply With Quote
Old 08-08-2019, 10:50 AM   #11
SquawkVFR
Drives: 2010 Camaro
NOWEEDS or cutouts?
SquawkVFR is offline   Reply With Quote
Old 08-08-2019, 10:56 AM   #12
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
he has no cats, door closed.. not a good combo lol
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 08-08-2019, 02:11 PM   #13
Greenhornet2
Bro we could have traded. I have ataks and probably need the S type lol.
Old 08-08-2019, 02:19 PM   #14
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
That's what I have. Cold start is a bit louder, cruise is as quiet as ever, WOT sounds awesome without being terribly loud.
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
exhaust, hoa, muffler delete, quiet exhaust, straight pipes
